Generator light staying on - Page 2 - Ford Truck Enthusiasts Forums
Old 07-23-2014, 06:59 PM
arctic y block's Avatar
arctic y block arctic y block is offline
arctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputation
If he dropped it or banged it while it was off for painting it may well just need polarized.
Old 07-23-2014, 07:35 PM
Tedster9's Avatar
Tedster9 Tedster9 is offline
Tedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputation
Just re-read your posts - if you painted the engine that won't help anything, the return path for the generator itself is through the block. Everything has to be clean and tight electrically speaking. If there is paint on the generator mounting pads, brackets and such, that might do it.
High resistance is especially a problem for generator systems. Check the regulator itself, too, it is grounded on the fender apron on mine, but still has a dedicated factory ground lead going to it for this reason.
Sent from my iPhone using IB AutoGroup
Old 07-23-2014, 08:19 PM
78 & 87 Super Cab's Avatar
78 & 87 Super Cab 78 & 87 Super Cab is offline
78 & 87 Super Cab has a good reputation on FTE.78 & 87 Super Cab has a good reputation on FTE.
Quote:
Nope, did not drop or bang it
I will check and clean the grounds to the
generator
Old 07-24-2014, 07:40 PM
Damifiknow's Avatar
Damifiknow Damifiknow is offline
Damifiknow is starting off with a positive reputation.
Mine looks like its on at night but its glow from adjacent lights.
Old 07-26-2014, 12:27 AM
Tedster9's Avatar
Quote:
That's a beautiful '60 there, Gus! Nothin' says "get outta my way" like a good solid brush guard.
Old 07-26-2014, 07:31 AM
Damifiknow's Avatar
Thanks, Its the dealer installed accessory. Pretty rare from what I've read. All I need now is an air horn.
Old 07-30-2014, 08:58 PM
Tedster9's Avatar
Any luck??
Old 07-31-2014, 11:09 AM
Wil try it out this weekend, been busy lately and haven't had a chance to start it back up
Old 08-04-2014, 07:27 PM
Tried it again today, light still stayed on. Took it off and had it bench tested at a small shop that still works on them. It put out nothing, completely dead
Old 08-04-2014, 07:41 PM
Maltman's Avatar
Maltman Maltman is offline
Maltman has a very good reputation on FTE.Maltman has a very good reputation on FTE.Maltman has a very good reputation on FTE.Maltman has a very good reputation on FTE.
here is what I did after regulator troubles on my truck-really simple install
http://www.summitracing.com/parts/tff-7068/overview/
Old 08-04-2014, 08:29 PM
cyclone-429's Avatar
cyclone-429 cyclone-429 is offline
cyclone-429 is starting off with a positive reputation.
Same for me....
Old 08-06-2014, 02:21 PM
I have access to a friend that has several good GM alternators, now
where can I source the 1 wire regulator, do parts stores carry it?
  #28
Old 08-06-2014, 03:38 PM
Maltman's Avatar
the ford alternator link I sent only has 1 ground wire and 1 wire to the battery, no external regulator needed sir
  #29
Old 08-06-2014, 03:52 PM
I know, I am wanting to do this cheaper than 82 bucks
  #30
Old 08-06-2014, 03:59 PM
Maltman's Avatar
I see said the blind man to the deaf mule, the regulators I saw were from $40-$120 but those were the OE style...wish I could help ya more
Help 2 issues Bigdogca1966 1999 - 2003 7.3L Power Stroke Diesel 6 03-27-2016 05:26 PM
Alternator/generator light dimly lit once truck is started asmith6 1961 - 1966 F-100 & Larger F-Series Trucks 9 03-05-2016 06:34 AM
63 f100 generator issue Combatwombat 1961 - 1963 F100 Unibody 3 04-21-2015 05:29 PM
Generator Issue? 46fordgal 1947 and Older Ford Trucks 24 04-10-2015 08:22 AM
P1148 code and charging light altruego 6.0L Power Stroke Diesel 7 01-17-2013 07:42 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
