Generator light staying on
Old 07-23-2014, 05:59 PM
arctic y block's Avatar
arctic y block
arctic y block is offline
If he dropped it or banged it while it was off for painting it may well just need polarized.
Old 07-23-2014, 06:35 PM
Tedster9's Avatar
Tedster9
Tedster9 is offline
Just re-read your posts - if you painted the engine that won't help anything, the return path for the generator itself is through the block. Everything has to be clean and tight electrically speaking. If there is paint on the generator mounting pads, brackets and such, that might do it.
High resistance is especially a problem for generator systems. Check the regulator itself, too, it is grounded on the fender apron on mine, but still has a dedicated factory ground lead going to it for this reason.
Sent from my iPhone using IB AutoGroup
Old 07-23-2014, 07:19 PM
78 & 87 Super Cab's Avatar
78 & 87 Super Cab
78 & 87 Super Cab is offline
Nope, did not drop or bang it
I will check and clean the grounds to the
generator
Old 07-24-2014, 06:40 PM
Damifiknow's Avatar
Damifiknow
Damifiknow is offline
Mine looks like its on at night but its glow from adjacent lights.
Old 07-25-2014, 11:27 PM
Tedster9's Avatar
Tedster9
Tedster9 is offline
That's a beautiful '60 there, Gus! Nothin' says "get outta my way" like a good solid brush guard.
Old 07-26-2014, 06:31 AM
Damifiknow's Avatar
Damifiknow
Thanks, Its the dealer installed accessory. Pretty rare from what I've read. All I need now is an air horn.
Old 07-30-2014, 07:58 PM
Tedster9's Avatar
Tedster9
Tedster9 is offline
Any luck??
Old 07-31-2014, 10:09 AM
78 & 87 Super Cab
Wil try it out this weekend, been busy lately and haven't had a chance to start it back up
Old 08-04-2014, 06:27 PM
78 & 87 Super Cab
Tried it again today, light still stayed on. Took it off and had it bench tested at a small shop that still works on them. It put out nothing, completely dead
Old 08-04-2014, 06:41 PM
Maltman's Avatar
Maltman
Maltman is offline
here is what I did after regulator troubles on my truck-really simple install
http://www.summitracing.com/parts/tff-7068/overview/
Old 08-04-2014, 07:29 PM
cyclone-429's Avatar
cyclone-429
cyclone-429 is offline
Same for me....
Old 08-06-2014, 01:21 PM
78 & 87 Super Cab
I have access to a friend that has several good GM alternators, now
where can I source the 1 wire regulator, do parts stores carry it?
  #28
Old 08-06-2014, 02:38 PM
Maltman's Avatar
Maltman
Maltman is offline
the ford alternator link I sent only has 1 ground wire and 1 wire to the battery, no external regulator needed sir
  #29
Old 08-06-2014, 02:52 PM
78 & 87 Super Cab
I know, I am wanting to do this cheaper than 82 bucks
  #30
Old 08-06-2014, 02:59 PM
Maltman's Avatar
Maltman
Maltman is offline
I see said the blind man to the deaf mule, the regulators I saw were from $40-$120 but those were the OE style...wish I could help ya more
Quick Reply: Generator light staying on
