Quick help: after water pump install truck bogs down?! - Ford Truck Enthusiasts Forums
Old 07-22-2014, 02:07 PM
wolff7.3 wolff7.3 is offline
wolff7.3 is starting off with a positive reputation.
So my friend with a '97 f350 replaced his water pump last night and now when he first starts it up it bogs down real bad until it warms up? Never happened before, Has 220,000 miles automatic. Any help would be much appreciated
Thanks
Old 07-22-2014, 02:25 PM
fordpride's Avatar
fordpride fordpride is online now
fordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant future
Just a wild azz guess. Is maybe he broke the exhaust back pressure sensor and it's shorting causing the ebpv to close. That's the only thing I can think off
Old 07-22-2014, 03:13 PM
Thanks man! He's diving in to that right now
Acceleration issue - no codes Jerseylandscaper 1999 to 2016 Super Duty 4 06-22-2015 06:52 PM
Newbie Here justminsa 1987 - 1996 F150 & Larger F-Series Trucks 1 04-13-2015 09:41 AM
Will a bad tuque converter bog down the motor 02GrayPowerStroke 1999 to 2016 Super Duty 3 02-20-2015 06:27 PM
Bogging down problem..ideas? 5th One 1997 - 2003 F150 9 11-12-2014 07:57 AM
f150 bogs down after replacing water pump ajmalo 1987 - 1996 F150 & Larger F-Series Trucks 2 08-24-2014 12:43 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
