Will better shocks do any good on a f250 ?
Ill be trading my 98 f150 for a 87 f250 with a 6.9 and 4 inch lift. And i test drove it and yep it drove like a older 3/4 ton lol So i was wondering if i got some really nice shocks if thatll help the ride for off road. Or will it always ride that rough because of the bigger leave springs... So basically is it worth the money to get some really nice shocks ? its got ranchos now
You need to inspect your entire suspension first before drawing any conclusions. I had a terrible ride on my 88 f250 and it turned out to be solved with new shocks and reworking the sway bar links... I've been pretty comfortable for the last 2-3 years now with the new suspension work.
https://www.ford-trucks.com/forums/1...with-pics.html
Take your shocks off and push them down and see if they rebound. If they don't rebound pretty quickly or don't rebound at all you need to replace them. Too many people ignore $100-$300 in suspension parts/work when it will make a world of difference in how your truck rides and handles.
If you're original shocks are no good, then you will notice a little difference.
When I replaced my original shocks they were completely shot(they just stayed fully extended) I used Skyjacker 7000 Hydro's all the way around, they definitely made a difference, so now it rides a little less like a tank....lol
on
Good shocks will help to reduce the speed at which stiff springs move through their normal motion, thus quelling the 'jarring' effect of a 3/4 or 1 ton suspension setup as it reacts to irregular road surfaces.
Poor shocks will not have the damping strength to counter the springs.
Cheap shocks may actually make a truck's ride poorer.
I like Bilsteins, but I'm sure a good set of Ranchos, especially the adjustable ones, would do the trick.
The shocks (Monroe) in my F350 were shot when I got it, and driving over local pot holed roads, it felt like the only suspension was in the seat. Put Bilsteins on, and suddenly, I could feel the suspension working and the wheels staying in contact with the road.
Still rides like a one ton, though...
hmmm ok thanks guys, yeah iv heard from other people say that ranchos ride on the stiff side, and bilsteins ride alot softer. I had some on my ranger and they were awesome i did some hard wheeling on those, but a little range is waay lighter then are tanks. I was looking into the bilsteins 5100s, but thats a $400 set up witch ill pay if it helps. Only because i go down alot of pot holed drive ways and logging roads
I put F250 springs in my F150, she rode pretty rough. Shocks were junk. Put Bilstein 4600 HD's on (bought on Eshocks.com for $280) and it was better. Still firm, but as others stated less harsh and handles washboard much much better. The on-road improvement was noticeable but not drastic, off-road is where the huge improvement was.
on
more than likely,the best upgrade one could make to the hd platform (f250/350) would be to swap out to some '99+ super duty leafs.
just keep in mind,those newer super duty trucks don't hold a load like our old truck due to their long flexy leafs.they will look bottomed right out and pointing to the sky when our trucks will level out.that's the drawback there.that's why so many who need to load their SD's install air bags cus they can't take the load like the older rigs.they ride a heck of a lot nicer though.pro's and con's.it's always pro's vs the cons.
Well actually yep ill be needing new tires soon once i get the truck and was going to get some 35 inch load D tires for a softer ride off road. Because the only reason why im getn this truck is to haul horses so theres not going to get alot of weight on my truck to were id need a load E tire. Saying that what do you guys think about me taking out that upper helping leaf spring thats for extra bed weight, will that help much. kind of like what FORDF250HDXLT was saying how the newer f250s dont have that and need the air ride to leave out there truck where these old trucks have them big leave spring helpers
FordFETruck
19
06-17-2012 02:11 PM
tomtoc
07-09-2007 05:09 PM
76 F250 4X4
09-13-2004 02:16 AM
