2004 Explorer Vacuum Leak Driver Side
I replaced plugs, wires and ignition coil about 6 months ago because of rough idle. the ruff idle continues and now there is a swishing sound as it idles on the drivers side of the engine. I have seen multiple possible reasons for this, and I am trying to narrow down what to attack next. It definitely sounds like a vacuum issue, but the question is, what and where is it?
Explorer has 230k miles on it. V6 4.0 L SOHC
Also check your air intake snorkel. Maybe it's not tight. The PCV valve and the EGR are both connected to manifold vacuum so they are potential suspects.
I'm probably missing stuff, not to mention I haven't included things like injector o-rings and intake gaskets. Start with the easy and quick stuff first. An EVTM (electrical and vacuum troubleshooting manual) would be helpful. Documentation is good.
tylerj4
02-02-2011 10:23 PM
