Oil Pan Leak behind harmonic balancer - Ford Truck Enthusiasts Forums
Old 07-22-2014, 09:04 AM
Eddie C Eddie C is offline
Eddie C is starting off with a positive reputation.
I have noticed a small leak from my oil pan behind the harmonic balancer. The leak doesn't appear to be significant, but it's still a leak and should be fixed. The oil level read on the dipstick hasn't dropped below the full-line, but I'd still like the fix the leak with some help; it looks like the gasket has just worn down. This is a 95 F250 4x4 turbodiesel 7.3 with 197,000 miles. I doubt the gasket has ever been changed.
Thank you
Old 07-22-2014, 09:15 AM
DIYMechanic's Avatar
DIYMechanic DIYMechanic is offline
DIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to behold
I think you'll just want to leave it alone.
If it is the oil pump (which sits just behind the balancer) it might not be too bad a job, but if it is indeed leaking from the front cover, or the pan gasket the engine has to come out to replace the seal or gasket. It is possible that a new LPOP would take care of it though. That's about as far as I would be willing to go to fix a slight leak.
Old 07-22-2014, 03:38 PM
Is there a way to determine if the LPOP is bad? My gauge shows normal pressure and the truck is not running hot.
Old 07-22-2014, 03:54 PM
It wouldn't necessarily be that the pump is bad, just that it could be leaking. Your best bet is to get it all cleaned up with parts cleaner or a pressure washer or something and then see exactly where the oil is coming from. If it's the LPOP, it maybe worthwhile to replace it if the leak really bothers you. If it is from the pan or the front cover, it's not really worth it unless that little leak REALLY bugs you.
Old 07-22-2014, 04:28 PM
91 Dually 91 Dually is offline
91 Dually is gaining momentum as a positive member of FTE.91 Dually is gaining momentum as a positive member of FTE.
My bet is it"s the press in seal that presses into the lpop and seals to the harmonic balancer itself. When I did mine, the balancer had a nice little groove worn into it where the seal rides on it. The seal that I bought came with a thin sleeve that presses onto the balancer shaft to give the seal a smooth surface without the groove to seal to. I just put a little threadlock on the shaft and used a piece of the correct size exhaust pipe to drive the sleeve on. Mine doesnt leak anymore.... Or. it could be the lpop seal. It is just a large o-ring that fits into a groove on the back side of the lpop. I just put a little of the Ford gray silicone on it and bolted it on. no leaks yet.
If it is actually the oil pan leaking, you have to pull the engine to reseal that.
Harmonic balancer cut groove into timing cover Dingo4x4 Ford Inline Six, 200, 250, 4.9L / 300 12 01-24-2017 10:21 AM
Inline 300-6 Oil Leak & Gasket Replacement Question (1984 f-150) jmb2011 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 4 01-30-2016 04:35 AM
Leak behind harmonic balancer copen93 1987 - 1996 F150 & Larger F-Series Trucks 12 11-25-2014 10:08 PM
Harmonic Balancer Question 300 Six 1918ALF Ford Inline Six, 200, 250, 4.9L / 300 4 10-05-2013 06:22 AM
I think my truck hates me... Dave145 1973 - 1979 F-100 & Larger F-Series Trucks 15 08-12-2013 11:13 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
