1964 292 - Ford Truck Enthusiasts Forums
1964 292
Old 07-22-2014, 09:03 AM
Shadowrider123 Shadowrider123 is offline
Shadowrider123 is starting off with a positive reputation.
1964 292
I just bought a 1964 F100 with a 292/AT.
Im very disappointed with the performance of the engine. It runs well but has no power. I floored it yesterday, the tranny dropped a gear, the rpm increased, but the truck didn't go any faster.
It has the oil bath air cleaner and the original crossover exhaust manifolds that run through a 1 3/4 single exhaust with a big round muffler that is about 3 feet long. I think it has a 57-ish rear end with 3.10 gearing. The rear end does not look original to the truck and the tag on the pumpkin says 3 1 0, I know that is that is not correct for a 64 F100.
My questions:
Is this a LOM setup?
At idle what should the oil pressure be? there is a cheap mechanical gauge installed, at idle it reads almost zero, about 20psi at cruising. I have no idea how accurate the gauge is.
Is it worth freshening up the 292 and installing headers and a dual exhaust?
Im not looking to go fast in a heavy truck shaped like a brick, but I would like to be able to chirp the tires if I want to.
Old 07-22-2014, 10:02 AM
Tedster9's Avatar
Tedster9 Tedster9 is offline
Tedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputation
"It runs well but has no power"
Doesn't sound like it's running well then. Is it timed correctly? Very common issue with Y blocks.
Another thing to look at is the carburetor linkage.
#1 mistake when a replacement carb is installed, failure to ensure the butterflies open all the way when floored. I managed to replicate these and other issues with my 64. As I mentioned in the other thread, there's something else going on here that needs to be remedied before condemning the 292. Put a vacuum gauge on the manifold and see how much you're pulling.
Sent from my iPhone using IB AutoGroup
Old 07-22-2014, 11:12 AM
It does run well.
Smooth idle, no knocks, no oil smell, no vibration.
I will check the timing and vacuum reading this afternoon.
Im going to the muff shop and getting the can whacked off it now.
I will put a single turbo on until I decide what to do with it.
Old 07-22-2014, 12:26 PM
Tedster9's Avatar
Well - guess it might hinge on what the definition of "runs well" is. Your observations indicate it certainly could run a whole lot better - "truck has difficulty reaching 55 mph", etc. The alternative is something else going on, unrelated to engine or engine tuning.
Not trying to argue, my truck was a real dog until a few issues were remedied chiefly ignition timing and distributor issues, and proper carburetor setup and tuning. The difference was night and day.
Old 07-22-2014, 05:49 PM
charliemccraney charliemccraney is offline
charliemccraney is gaining momentum as a positive member of FTE.charliemccraney is gaining momentum as a positive member of FTE.
I agree that it's not running at it's best. I don't know if it should be tire scalding (never driven a fresh, stock '64 292) but it should accelerate fairly well.
The 3.10 gearing can definitely be affecting it.
It should not have a LOM distributor but after 50 years, it could have anything.
The oil pressure is really low. Try a different gauge first. If there is no change, you might drop the pan and make sure the pick up is not clogged and perhaps rebuild or replace the pump. If there is still no change, then it is time for a complete rebuild.
It is worth freshening up and dual exhaust is probably the single best upgrade you can make. Another good one is a 4 barrel carb and intake and tuning the ignition advance curve.
Old 07-22-2014, 06:33 PM
If it needs a refresh I will probably go with a 5.0 and a C4.
I would rather keep the 292 and add either ramhorns or headers.
Im fine with the 2V, I didn't see a lot of choices for a 4V manifold.
The shop didn't have time to do my muffler today, so it looks like tomorrow morning.
1964 f100 240 motor swap dodgers72 1961 - 1966 F-100 & Larger F-Series Trucks 14 05-05-2015 09:58 PM
1964 Ford F600 292 exhaust manifold replacement arvet19 Large Truck 6 04-10-2015 03:55 PM
1964 f100 air cleaner DGMFORD 1961 - 1966 F-100 & Larger F-Series Trucks 12 08-22-2014 05:55 PM
Air Filter Too Small Macs1964F100 1961 - 1966 F-100 & Larger F-Series Trucks 16 07-26-2014 11:31 PM
1964 F100 Engine and Transmission Change out question mlwhite77 1961 - 1966 F-100 & Larger F-Series Trucks 3 05-26-2012 06:25 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
