Won't idle in gear...
I dropped a valve in my 1979 Ford F-150 351M back in 99, I haven't driven the truck since... The reason was money... I'm now finally ready to get it working again. I've bought an engine from craigslist the guy told me was a 351M, turns out it was a 400, and also turns out it was from a car, not a truck... Is this going to be an issue... The engine runs good, idles okay, about 700, no vacuum leaks, but as soon as I put it into gear it wont stay running...
I have an idea of what the problem might be but I wanted to get advice without putting my idea in any ones head, just to see if maybe someone says the same thing...
Thanks...
Thanks...
i swapped the motor 7 years ago i dont remember about the flex or balancer. i would think i used the 400s but not sure.
is this what your refering to? BWD/Intermotor Carburetor Idle Stop Solenoid ECS153: Get best Fuel Injection Pump Stop Solenoid at Advance Auto Parts
i dont even know where this would plug in...
on
Yes something like that but it would be on a bracket that bolts to the carb, and you would have a plunger that kicks out and increases idle speed when in gear or a/c is turned on if you have it, some also tie into the p/s so when you turn your idle bumps up, you dont stall out during a turn, what happens when you raise the idle speed a couple clicks? bring her up too about 800 rpm and see if she still stalls.
bdevr
09-14-2011 05:35 PM
Bluto
18
08-04-2009 08:33 PM
