Transmission slipped out of gear while driving. - Ford Truck Enthusiasts Forums
Old 07-22-2014, 12:26 AM
Leatherneck514 Leatherneck514 is offline
Leatherneck514 is starting off with a positive reputation.
Unhappy Transmission slipped out of gear while driving.
1996 F250 7.3L Turbo Automatic
I was driving home this evening and after stopping at a Stop sign. I pulled out on the road and started driving then all of a sudden I had not transmission. No gear would work. I coasted into a driveway and tried reverse. NOTHING happened. I put it in Park and it started grinding loudly and then seemed to go in. There was a different smell coming from under the truck but couldn't see anything wrong. I turned the truck off and then back on no change. I noticed that the Park position would go past the P indicator easily. I don't think it actually was going into park. I was able to put it into the Neutral position push the truck with it running, at least we think. I was able to push it to a parking lot so it seems to be either in nuetral or not connected.
Never had ANY kind of issue with the transmission,
What happened????? Any ideas????
Thanks!!!
Old 07-22-2014, 02:29 AM
Spktyr Spktyr is offline
Spktyr is gaining momentum as a positive member of FTE.Spktyr is gaining momentum as a positive member of FTE.
Is it a 4 wheel drive?
Old 07-22-2014, 10:00 AM
Yes it is a 4x4 (currently no shaft on drivers side so can't lock in the front).
Well I got to the truck this morning an looked it over. I can change the gears and the transmission shifts fine. The back axle gears seem to have blown apart.
Old 07-22-2014, 10:07 AM
David7.3's Avatar
David7.3 David7.3 is offline
David7.3 is a splendid one to beholdDavid7.3 is a splendid one to beholdDavid7.3 is a splendid one to beholdDavid7.3 is a splendid one to beholdDavid7.3 is a splendid one to beholdDavid7.3 is a splendid one to beholdDavid7.3 is a splendid one to behold
Yep, that was going to be my guess, when you put it in park the driveshaft was still spinning, causing the grinding noise. Now pull the rear shaft and put the front back in. that should buy ya some time.
Old 07-22-2014, 10:50 AM
Thanks for your help!!! I'll have it apart (hopefully later today) and rebuilt. I'll keep ya posted.
Old 07-22-2014, 11:51 AM
jchosler's Avatar
jchosler jchosler is offline
jchosler is starting off with a positive reputation.
Carzy, I figured thos gears would be tougher then that. At least while under significant stress
89' F-150 M5OD-R2 Issue ThatGuy79 1987 - 1996 F150 & Larger F-Series Trucks 32 11-24-2014 10:16 AM
2002 Escape, V6 3.0 2WD, CD4E Prob WB4IUY Clutch, Transmission, Differential, Axle & Transfer Case 4 10-06-2014 07:33 AM
c6 transmission problems jims1956 Clutch, Transmission, Differential, Axle & Transfer Case 0 09-12-2014 09:55 AM
HELPPPPPPPPPP!!!!!!!!!!!!!!!!! TRANNY ISSUES Tractorman1215 1987 - 1996 F150 & Larger F-Series Trucks 25 07-29-2013 08:11 PM
TPS? Transmission problem drivembig 1994.5 - 1997 7.3L Power Stroke Diesel 4 06-14-2010 11:54 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
