do all 351w have dual outlet factory tips? - Ford Truck Enthusiasts Forums
Old 07-21-2014, 11:09 PM
choate's Avatar
choate choate is offline
choate has a good reputation on FTE.choate has a good reputation on FTE.
I was talking to a muffler shop and he said you sure you have the 351 and I go yeah unless someone changed the label engraved on the motor. He said every diagram he looks at for the 351 has dual exits on the passenger side. Mine only has one. I kind of forgot about it and was helping this guy who was having trouble at the gas station starting a 1995 F250 he just bought and he said it had the Windsor and sure enough his exhaust has dual side exits! I don't know that I really like the look of it to be honest but is that how they all came from the factory w/ a 351?
Old 07-22-2014, 12:39 PM
Nothing Special's Avatar
Nothing Special Nothing Special is online now
Nothing Special has a great reputation on FTE.Nothing Special has a great reputation on FTE.Nothing Special has a great reputation on FTE.Nothing Special has a great reputation on FTE.Nothing Special has a great reputation on FTE.
My '85 F-250 and my '95 F-150 both had 351s and single exhaust tips. The '85 was bought new, so I'm sure that was factory. The '95 was 3 years old with 27K on it when I bought it, so it's possible (but unlikely given the low miles) that it was changed by the original owner.
Old 07-22-2014, 01:06 PM
skyfox10's Avatar
skyfox10 skyfox10 is offline
skyfox10 has a very good reputation on FTE.skyfox10 has a very good reputation on FTE.skyfox10 has a very good reputation on FTE.skyfox10 has a very good reputation on FTE.
I've had a 95 and 96 F150. Both 351, both single right hand side exhaust.
Old 07-22-2014, 02:08 PM
Nighteyez's Avatar
Nighteyez Nighteyez is online now
FTE NorCal chapter LDR
Nighteyez has a spectacular reputation.Nighteyez has a spectacular reputation.Nighteyez has a spectacular reputation.Nighteyez has a spectacular reputation.Nighteyez has a spectacular reputation.Nighteyez has a spectacular reputation.Nighteyez has a spectacular reputation.Nighteyez has a spectacular reputation.Nighteyez has a spectacular reputation.Nighteyez has a spectacular reputation.Nighteyez has a spectacular reputation.
I had a 93 Bronco with the 351 and it had a single outlet as well.
Jim
Old 07-22-2014, 02:12 PM
rla2005's Avatar
rla2005 rla2005 is offline
rla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud of
I always thought the 5.8L trucks had dual tail pipes too..
5.8L
5.0L
Old 07-22-2014, 02:16 PM
Evan_P's Avatar
Evan_P Evan_P is offline
Evan_P is a splendid one to beholdEvan_P is a splendid one to beholdEvan_P is a splendid one to beholdEvan_P is a splendid one to beholdEvan_P is a splendid one to beholdEvan_P is a splendid one to beholdEvan_P is a splendid one to behold
My '92 did...
Old 07-22-2014, 02:19 PM
rla2005's Avatar
Quote:
Originally Posted by Evan_P View Post
My '92 did...
So did my old '92 F350 w/5.8L engine
Old 07-22-2014, 03:13 PM
choate's Avatar
Bizarre. My exhaust look exactly like the 5.0 diagram. I have a Y with the O2 in the center of that, then a 2nd cat and a one in one out muffler. I wonder if somebody re-did the entire exhaust? My truck was low miles 44k when I bought it but it for sure has a new muffler and new pipe from the muffler back. It just looks a lot newer than the other up stream piping. It has a heat shield too and it's def not 2.25 at the cat. More like 3" into 2.5 then down to 2.25
Old 07-22-2014, 11:05 PM
blkF250HD's Avatar
blkF250HD blkF250HD is offline
blkF250HD is gaining momentum as a positive member of FTE.blkF250HD is gaining momentum as a positive member of FTE.
Mine had the dual tailpipes too.
Old 07-23-2014, 06:40 AM
dixie460's Avatar
dixie460 dixie460 is offline
dixie460 has a good reputation on FTE.dixie460 has a good reputation on FTE.dixie460 has a good reputation on FTE.
My 96 had single exit exhaust on it.
Old 07-23-2014, 10:29 AM
choate's Avatar
Quote:
Maybe it's only the heavy duty trucks? The guys that I helped was an F250 too
302/351W or 360/390FE in '52? GoldCo 1948 - 1956 F1, F100 & Larger F-Series Trucks 43 01-09-2016 10:41 PM
390 rebuild questions/thoughts kadrocker 1973 - 1979 F-100 & Larger F-Series Trucks 4 06-08-2015 03:13 AM
Frame rail width difference FarmerBill 1973 - 1979 F-100 & Larger F-Series Trucks 0 07-12-2010 11:28 PM
HELP!! what block is this, Windsor or Cleveland?? BRay09 1987 - 1996 F150 & Larger F-Series Trucks 17 07-12-2009 05:38 PM
Aftermarket exhaust nuts4hotwheels 1968-2013 Full Size Vans 5 01-24-2006 07:56 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
