5.8L exhaust question
I am fixing up an 89 f150 xlt with a 5.8L i just ordered bbk shorty headers. I am planning on splitting the exhaust out of a magnaflow muffler out the back. I am eliminating the CAT and o2 sensors. Is a 3" exhaust pipe from the headers back too much. will it cause a back pressure issue if i go that big? any feedback will be much appreciated.
I've been considering something similar. Question on the O2 sensor: how important is the location, and is there a major effect if you run it on just one bank? I realize as you move back the system temp may change, but I would think the O2 levels would be the same. Could one run duel exhaust and simply change the location of the O2 sensor to just read one bank?
When you have OBD-II that is a different story. Both sensors need to be very close to the factory location.
Dekoda, check out Speed Daddy headers. They're 304 stainless steel and $188.00 for our 351w. I did read one person on here that complained of fitment issues where the tube had to be dimpled in a spot or two and a couple of welds grounded down to make it all work but I would expect that with such a low cost product. They look great though and shouldn't rust. Check to make sure they will fit your truck. These are for a 1989 F250 regular cab XL model b/c I didn't know the details of your truck but I would think it's about all the same
RACING SS MANIFOLD HEADER/EXHAUST 87-96 FORD F-150/F-250/BRONCO PICKUP 5.8L V8
The "Summit Racing brand" headers are a good option if you're looking to keep it on the cheap. They just give you Pacesetter headers for cheaper than you can buy the Pacesetters for. Be prepared to repaint them with better paint though, the paint they come with will flake off immediately.
krazybob
09-15-2004 07:19 AM
