6.0L Powerstroke swap into 75' F150 - Ford Truck Enthusiasts Forums
General Diesel Discussion SPONSORED BY:
Old 07-21-2014, 05:25 PM
GM4WALLS's Avatar
GM4WALLS GM4WALLS is offline
GM4WALLS is gaining momentum as a positive member of FTE.GM4WALLS is gaining momentum as a positive member of FTE.
I have the opportunity to pick up a complete rolling chassis with a low mile 6.0L PS. How hard will this conversion be with a rolling, driving donor? Next question, I know the 6.0L is not a desirable motor... What are the exact issues?
Old 07-22-2014, 11:35 PM
m-chan68's Avatar
m-chan68 m-chan68 is offline
m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.
FABRICATION FABRICATION FABRICATION.
It's called remove the bed and cab from your '75 and transplant it onto the rolling donor 6.0L powered chassis. All the work will be the fabricating needed to get it all to bolt up, and yet retain the appearance of your '75. Going this route I suspect will be simpler than trying to transplant the 6.0L into the '75 chassis.
Old 07-23-2014, 04:37 PM
GM4WALLS's Avatar
Frame on the F-250 is bent. Would I need to keep the instrumentation for Diesel truck?
Old 07-23-2014, 05:44 PM
tjc transport's Avatar
tjc transport tjc transport is offline
i ain't rite
tjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputation
every single electrical part of the 6.0 will need to be put into hte 75, and you will also have to swap the rear axle into the frame to make the speedometer work.
then you will have to swap out the front suspension to support the weight of the diesel engine.
and you will have to strengthen the frame to handle the added power.
Old 07-23-2014, 07:50 PM
GM4WALLS's Avatar
The instrumentation from the newer truck is needed? That kills it for me. Thank you for the input.
Old 07-24-2014, 05:00 AM
i ain't rite
the new truck dash is electric. the old truck dash is mechanical
BAK Roll X BlackNM6.0 6.7L Power Stroke Diesel 2 07-09-2014 06:24 PM
New User SuperDuty Bundy New Member Introductions 1 05-25-2014 10:28 AM
PM 22 Bsherry 6.7L Power Stroke Diesel 15 05-04-2014 07:40 PM
6.0L Cab swap on to a 7.3L truck DemonRace6 1999 - 2003 7.3L Power Stroke Diesel 10 03-21-2014 05:07 PM
Racor CCV 3500 or 4500? MoyockPowerstroke 6.0L Power Stroke Diesel 0 05-13-2009 10:49 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
