Instrument cluster with tach swap in 1993 F-150! - Ford Truck Enthusiasts Forums
Old 04-23-2002, 12:23 PM
MikeS MikeS is offline
MikeS is starting off with a positive reputation.
Has ANYONE done this swap successfully in a 1993 F-150? I have a 1993 with 5.0 and E4OD. I bought a cluster with a tach and hooked it up. Everything worked except the voltmeter. After further inspection of both clusters, I found the laminated circuit board to be different in the voltmeter area. So what changes? The circuit board or the wiring into the plug. I just would like to hear of someone that did it. I bought the cluster from someone that had a 95 and said this was from a 93. He believe it had to be same year to make the swap. When he hooked it up on his 95 the voltmeter did not work and the alternator would not charge. I cleaned all contacts and tested gauge with 9 volt battery and it responded. The circuit has a 92 part number on it. I can't believe it changed from 92 to 93!!! My truck is a speed density system. Either the circuit board changes or the wiring to the plug changes. Would really like to hear a success story. Has to be a 92-96 story. 87-91 is a different story.
Old 04-24-2002, 01:43 AM
charlez's Avatar
charlez charlez is offline
charlez is starting off with a positive reputation.
I did this swap in my 93 with a 93 salvage cluster. All I did was take them apart switch the speedos and plug it in. Everything worked and I didn't have to change any wiring.
(your truck or at least the cluster was probably made in late 92, hence the 92 label)
Any more questions? I may be able to help.
Old 04-30-2002, 08:56 PM
RWADE8188 RWADE8188 is offline
RWADE8188 is starting off with a positive reputation.
I also bought a junkyard cluster from a 95 with no roof on it and changed it into my 92 in the parking lot with no problems . Everything worked fine. I did have to recal. the speedo for my35's.I have a 92 f250 4x4 with 3" susp. lift and 3" duals
Old 04-30-2002, 09:08 PM
fjones fjones is offline
fjones is starting off with a positive reputation.
On the '95 cluster was the bright headlamp indicator and ABS light in the same place as your '92? If they were not in the same place, did they work ok? I have a '92, and I'm thinking about buying a cluster for a '94. Think it might work. Thanks
Old 05-01-2002, 02:18 PM
Ford501 Ford501 is offline
Ford501 is starting off with a positive reputation.
Old 05-03-2002, 07:09 AM
clerk clerk is offline
clerk is starting off with a positive reputation.
There is a difference in the location of the pins in the plugs between 93 and 95 because of the addition of an air bag warning system light. What you have to do is to relocate several wires in the two connectors that plug into the cluster.
The way I did it was to get a wiring diagram from my friendly Ford dealer shop -- I photocopied the diagrams from the 95 and the 93 and studied them. The color codes for the wires are the same between the years just the location changed.
Looking at the plug straight on the bottom row of pins are numbered 1-7 going left to right. The top row goes the right to left with numbers 8-14.
The LG/R wire #904 moves from location 11 in its orginal plug to number 1 on the other plug. Number 12 on the same plug is R/LG #16 must move to Number 14 on the other plug. Number 14 moves to number 13 on that plug. Numbers 2 and three must be reversed in the original plug.
So two wires move to the other plug Number 16 R/LG goes from 12 to 14 and Number 11 pin moves to number 1 pin on the other plug Circuit 904 LG/R.
It is best if you can get the original diagrams just to help you sort it out.
If you need copies I think I have them or can readily get them.
Good luck.
Old 02-25-2014, 10:39 PM
Toplait's Avatar
Toplait Toplait is offline
Toplait is starting off with a positive reputation.
I'd like a copy if you still have it laying around. I'm trying to swap a 1995 lightning cluster into my 1992. The Haynes' and Chilton's repair manuals provided some information but made it look like all the years are the same...
Old 02-26-2014, 12:12 AM
Evan_P's Avatar
Evan_P Evan_P is offline
Evan_P is a splendid one to beholdEvan_P is a splendid one to beholdEvan_P is a splendid one to beholdEvan_P is a splendid one to beholdEvan_P is a splendid one to beholdEvan_P is a splendid one to beholdEvan_P is a splendid one to behold
Your likely not going to get a reply as the thread has not been touched in nearly 12 years and the guy with the diagrams you seek has not posted in over 3 years...
Old 02-26-2014, 05:34 AM
Bob Gervais's Avatar
Bob Gervais Bob Gervais is offline
Bob Gervais has a great reputation on FTE.Bob Gervais has a great reputation on FTE.Bob Gervais has a great reputation on FTE.Bob Gervais has a great reputation on FTE.Bob Gervais has a great reputation on FTE.
Quote:
You need a cluster from a 92/93. 94/95 clusters were different.
Old 02-26-2014, 08:44 AM
subford's Avatar
subford subford is online now
subford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud of
92 and 93 are the same clusters. You have a 94 or 95 cluster.
A 1994 or 1995 cluster will not charge the battery when put in a 1992 or 1993 gas truck.
To make it charge you have to swap wires between the two plugs.
1993 C250:
1993 C251:
95 or 92 C250:
94 or 95 C251:
Old 02-27-2014, 08:35 AM
zackcj7's Avatar
zackcj7 zackcj7 is offline
zackcj7 is gaining momentum as a positive member of FTE.zackcj7 is gaining momentum as a positive member of FTE.
Subford do you have the pinout for a '97 F250 or F350? I have a '94 F250 with 460, E4OD, 4X4. My local junkyard has a '97 F350 with 460, E4OD, 4x4 with a tach cluster. Just curious if it would work.
Old 02-27-2014, 10:36 AM
subford's Avatar
I have the ones for a 1997 F150-F250 but not the ones for the 1997 F250-F350,
they are not listed in the Ford manuals.
Old 02-27-2014, 11:22 AM
zackcj7's Avatar
The yard only wants $30 for it. I think i'll go ahead and buy it and try it out.
Thanks
92-93 versus 94-95 Gauges and Clusters TexasGuy001 1987 - 1996 F150 & Larger F-Series Trucks 23 09-13-2016 08:30 PM
XLT to lightning Cluster Swap Easily Possible?? Chris Braun 1987 - 1996 F150 & Larger F-Series Trucks 13 05-12-2014 09:19 PM
guage cluster swap gone wrong (beeping) Bluethunder3320 1987 - 1996 F150 & Larger F-Series Trucks 4 03-30-2014 08:50 AM
HOWTO: 81-86 gauge cluster in 80 model (gauge models ONLY!) Rogue_Wulff 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 16 03-19-2012 08:38 AM
OE? Faria tach ... what have I got here? ClydeSDale 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 11 10-17-2010 08:57 PM
Tags
1993, cluster, f150, fi50, ford, instrument, light, lightning, numbers, pin, swap, swaping, tach, truck, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
