rear axle u joint size? - Ford Truck Enthusiasts Forums
Old 07-21-2014, 10:28 AM
Greg5OH Greg5OH is offline
Greg5OH is starting off with a positive reputation.
kwik kwestion,
what is the u joint size in a 1991 f350 auto 2wd for the rear axle?
Thanks.
(the one that between driveshaft and yoke on the rear axle)
Old 07-22-2014, 10:27 PM
LeoJr's Avatar
LeoJr LeoJr is online now
LeoJr has a good reputation on FTE.LeoJr has a good reputation on FTE.
Would it be different on SRW versus a DRW? Maybe someone will know your answer...
Old 07-23-2014, 03:58 PM
generalrazo generalrazo is offline
generalrazo is starting off with a positive reputation.
I was told an easy way to ID it is as follows. If it is held on with u-bolts and nuts, then it is a 1310. If it is is held on with straps and the bolts thread directly into tapped holes in the yoke, it is a 1330.
this might help as well.
U-Joint series identification
U joint issue Rollingscrapmetal 1973 - 1979 F-100 & Larger F-Series Trucks 12 12-18-2016 01:22 PM
Rear u joint question pat420swed Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 15 09-18-2015 03:38 PM
05 f350 4x4 u joint sizes? Greg5OH 1999 to 2016 Super Duty 0 08-07-2014 02:43 PM
HELP! Rear axle swap, different size yoke on new axle! NeXguy 1994.5 - 1997 7.3L Power Stroke Diesel 6 02-18-2011 03:38 PM
Need "strange" U-joint for axle swap Charles 1973 - 1979 F-100 & Larger F-Series Trucks 7 07-15-1999 12:21 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
