HEI dizzy that will fit? - Ford Truck Enthusiasts Forums
Old 07-21-2014, 01:51 AM
ATC Crazy's Avatar
ATC Crazy ATC Crazy is offline
ATC Crazy has a very good reputation on FTE.ATC Crazy has a very good reputation on FTE.ATC Crazy has a very good reputation on FTE.ATC Crazy has a very good reputation on FTE.
Back when I had my motor built, I got a Summit HEI style distributor for it. I could never get it to fit and clear the water neck. I even tried the water necks with the flat spot for clearance. Nothing. So I stayed with the stock dizzy.
Now, the motor is going in an '88 F350, and there is no ignition system in the truck as the EFI computer and all wiring has been removed. I want the HEI style to avoid tracking down a Duraspark system and having all the extra wiring under there.
Are there any water necks or distributors that I have missed that will work? I'm running an Edelbrock Performer intake.
If I have to, I will make a water neck to fit.
*Edit*
This is for a 460
Old 07-31-2014, 12:11 AM
Kruse Kruse is offline
Kruse is gaining momentum as a positive member of FTE.
Well, you said you've already tried it, so I guess I may have a wasted post here, but I remember doing something like this YEARS ago by using one from a Ford van.
Try a Four Seasons 84998, an application for an early 80s Ford van with a 460. You may have to take a hand grinder and massage a little bit of the corner off your distributor and some material off of the thermostat housing. If it actually does fit, you'll obviously have to plug a few of the accessory holes with pipe plugs. Also use the thinnest paper gasket you can find.
I'd try to talk you out of the HEI distributor, but that's probably a hopeless case.
Old 07-31-2014, 12:14 PM
Turbo Dog's Avatar
Turbo Dog Turbo Dog is offline
Turbo Dog has a good reputation on FTE.Turbo Dog has a good reputation on FTE.Turbo Dog has a good reputation on FTE.
I have an HEI style distributer from Assualt Racing in my 460 with one of the flat spot water necks and it fits fine. I have the electrical plug facing the carb, not sure why yours doesn't fit.
HEI dizzy upgrade jordandkaspar 1987 - 1996 F150 & Larger F-Series Trucks 2 09-09-2016 10:38 PM
HEI style distributor in '80 5.0 Xwarrior86 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 4 02-26-2016 04:17 PM
HEI dizzy and starter button wiring tjdad62 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 12-28-2014 07:01 AM
HEI distributor hits water outlet jimmyz469 1973 - 1979 F-100 & Larger F-Series Trucks 5 08-02-2014 03:12 AM
HEI Distributor? or just a points kit? 351Cleveland C4 1967 - 1972 F-100 & Larger F-Series Trucks 19 08-20-2013 08:12 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
