Steering issue Mustang II
I have a 55 F100 with a Speedway Mustang II kit with power rack. It seems like it wants to wander and when turning it is jerking. I have a cheap and I mean cheap tilt column. I plan on replacing the column whit a Jeep column that my son found ( I don't trust the aftermarket ones). My question is would the column cause this and or should I place a heim joint on the steering rods? Sway bar? I intend to go to a shockwave set up this winter. Thanks!
Trying to understand what you mean, do you mean the steering is "notchy" when turning and then when turned it wants to keep turning (poor return to center of the steering wheel)?
If so there could be binding in the steering setup, not sure how many joints or angles you are using to get to the rack. I have also had trash in the system cause this, flushing out the PS fluid took care of it.
I am just guessing that this is your issue since you are talking about replacing the steering column.
If you are toed out, you would tend to wander.
Also, adding more caster should help.... (think of shopping cart wheels - they always want to go straight due to the offset of the wheel axle vs. the axis about the entire wheel assembly rotates (draw two vertical lines through a picture of a shopping cart wheel - 1. through the wheel axis itself and 2. through the axis about which the whole wheel rotates. That offset is caster and creates steering that self centers. The angle vs. vertical is caster angle.
as been touched out... GM power steering pumps put out too much pressure / volume. A volume reducer fitting on the pump works, too for Saginaw style pumps.
Steering will tend to be notchy or twitchy when the pressures aren't compatible.
