Where does this wire go???? - Ford Truck Enthusiasts Forums
Old 07-20-2014, 05:30 PM
mchemical mchemical is offline
mchemical is starting off with a positive reputation.
My son and I changed the spark plugs in my 2004 F-150 Lariat with the
5.4 Triton V8,v3 engine. Thankfully, we got all 8 plugs out without breakage.
We do have a problem. There is an extra wire that we do not know where
it goes. This red wire come out of the coil/plug harness near the fire wall.
The end of the wire had a trumpet appearance and was about the size of
a dime. In the center was a round object about 3 millimeter in size. Over
all this terminal was very clean. The truck seem to be running fine.
Could anyone tell me where this attaches.
Thanks
Old 07-21-2014, 02:56 AM
ojai150 ojai150 is offline
ojai150 is starting off with a positive reputation.
Thanks
Are you sure its a wire , and not a small hard vacuum hose ?
Old 07-21-2014, 04:42 AM
Wire.....vaucum hose?
No, it is not a vacuum hose.
Thanks for asking.
Old 07-21-2014, 06:08 AM
where does it go
Thanks for asking.
Well, I really do not know for sure. It just does not appear to be a vacuum line.
Old 07-21-2014, 07:04 AM
David7.3's Avatar
David7.3 David7.3 is offline
David7.3 is a splendid one to beholdDavid7.3 is a splendid one to beholdDavid7.3 is a splendid one to beholdDavid7.3 is a splendid one to beholdDavid7.3 is a splendid one to beholdDavid7.3 is a splendid one to beholdDavid7.3 is a splendid one to behold
What side of the motor is this on, Is it just s single wire? I have a connector that hooks to the OPS under the intake, and some tritons have there knock senors mounted under there and more info and I will look under my hood again and see.
Old 07-21-2014, 07:14 AM
David7.3's Avatar
I checked my 04 again, the only thing I see on the passenger side is the red vacuum line that goes from the intake to the purge valve (MOUNTED ON FIREWALL) to the vacuum can.
Old 07-21-2014, 08:54 AM
Red Wire
Thanks Dave7.3 I will look and see if I can find it as you suggest.
Old 07-21-2014, 01:05 PM
Quote:
I would bet it is the 2nd part of the vacuum line that goes from the back of the intake on the passenger side to the fuel pressure valve
Old 07-22-2014, 11:21 AM
Now to find the loacation on the firewall
You are exactly correct Dave7.3. The trumpet looking part is part of the
purge control valve. ( I saw the part in parts catalog)The redline is a vacuum line.
Now to find this purge valve. Could you give me a little more instructions
on it exact location. Then I will have the job done.
Thanks Dave7.3
Old 07-22-2014, 11:53 AM
70f100longbed's Avatar
70f100longbed 70f100longbed is offline
70f100longbed has a very good reputation on FTE.70f100longbed has a very good reputation on FTE.70f100longbed has a very good reputation on FTE.70f100longbed has a very good reputation on FTE.
That red vacuum line goes to the 4wd hub solenoid and is not plugged into anything on 2wd trucks. The purge valve is on the driver's side next to the brake booster
Old 07-22-2014, 12:05 PM
Thank you for your reply.
F150 5.4L V8 vs. F250 5.4L V8 digruk Modular V8 (4.6L, 5.4L) 11 02-26-2015 09:20 PM
1997 F-350 Turn Signal Problems BillJones 1994.5 - 1997 7.3L Power Stroke Diesel 7 08-25-2014 03:53 PM
How to make your own glow plug wiring harness rosesrfree4u Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 12 07-12-2014 01:24 AM
97 F250HD w/ 5.8L Fuel Hydro-Locks #8 Cylinder qcy2k6 Fuel Injection, Carburetion & Fuel System 5 11-24-2009 05:07 PM
Installed Factory Dvd In Nav On Sunday - Horrray dean petrucelli 1997-2006 Expedition & Navigator 20 01-23-2005 01:14 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
