1988 7.3 idi stalled randomly and will not start - Page 2 - Ford Truck Enthusiasts Forums
Old 07-22-2014, 07:41 PM
joshofalltrades joshofalltrades is offline
joshofalltrades has a good reputation on FTE.joshofalltrades has a good reputation on FTE.
There are a few hundred threads around here about the electric pumps. The best is the facet duralift pump, but they're hard to find at local stores.
Basically you need a low pressure transfer pump made for diesel fuel not gasoline.
Old 07-22-2014, 07:50 PM
pat420swed pat420swed is offline
pat420swed is gaining momentum as a positive member of FTE.pat420swed is gaining momentum as a positive member of FTE.
Ok so I did some research, does anyone know if the dura lift fuel pumps are available in Canada and if so where? Ive onky been able to find them on websites that ship to the states only
Old 07-23-2014, 05:06 PM
Just to update ive ordered a Mr gasket 12D fuel pump from summit racing, thanks everybody for a
Old 07-25-2014, 07:29 PM
My one last question is that ive read about when the fuel pumps go they let fuel into the crank case? Does this happen everytime or is it a rare thing?
Old 07-25-2014, 10:18 PM
wtroger wtroger is offline
wtroger is gaining momentum as a positive member of FTE.wtroger is gaining momentum as a positive member of FTE.
Yes they can. Any diaphragm pump can do that.
Old 07-26-2014, 02:09 PM
Does it happen everytime or is it a a rare thing? Also does anyone have any tips on removing glow plugs with breaking tjem?
Old 07-26-2014, 02:30 PM
If they are Ford gp's they should come out clean. If some other brand then it gets dicey. A lot of folks try and with some success to remove swelled gp's by putting a chuck on them and holding pulling pressure on them and screwing out of the head basically threading them out.
Cooling Issue... KJNDIVER 1999 - 2003 7.3L Power Stroke Diesel 61 06-02-2016 09:33 AM
2010 f250 v10 lost all power ropetexas 1999 to 2016 Super Duty 6 11-21-2015 06:06 PM
No Start - When Hot OldWoodsDiesel 1994.5 - 1997 7.3L Power Stroke Diesel 14 03-11-2013 08:19 AM
08 F250 - Weird Problems alexmartin33 6.4L Power Stroke Diesel 7 08-01-2011 06:38 PM
1993 F250 Turbo Diesel won't start Flynndog 1987 - 1996 F150 & Larger F-Series Trucks 1 10-23-2010 12:58 PM
Tags
1988, 7.3, died, ford, idi, no start, pickup
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
