2009 F150 Crew Cab Door Lock Mystery - Ford Truck Enthusiasts Forums
Old 07-20-2014, 04:45 PM
Black Rapter Black Rapter is offline
Black Rapter is starting off with a positive reputation.
. I noticed that my rear drivers side crew cab door was not unlocking recently. So I got the tools out popped the trim and door panel off disconnected the window switch. Then I checked all the wiring for loose connections.when I tested the locks miraculously it worked again. Not knowing what really happened to fit it I figured it was a loose connection I re established. I re assembled the door put all my tools away ( which always jinxes me ) and found the lock was not locking again. I also noticed a funny thing in that when I had the door open the lock worked normally unlock and lock but with the door closed it would only lock and not unlock. Unless there is some kinda safety limit switch hosing things up I am confused.
Help Help Help !!!!!
Old 07-22-2014, 03:19 PM
1ATony's Avatar
1ATony 1ATony is offline
PREMIUM SPONSOR
1ATony is a splendid one to behold1ATony is a splendid one to behold1ATony is a splendid one to behold1ATony is a splendid one to behold1ATony is a splendid one to behold1ATony is a splendid one to behold1ATony is a splendid one to behold
Welcome to the site.
Tony
__________________
Like us on Facebook
SHOP HERE FOR AWESOME BRAKE PAD AND ROTOR KITS - FREE SHIPPING
Old 07-24-2014, 10:04 AM
space1979 space1979 is offline
space1979 is starting off with a positive reputation.
most likely broken wire in accordion rubber door conduit
similar situation. 2009 f-250 crew cab. LH rear door wires broke in the rubber conduit. 2 touched that shouldn't have and the door locks quit working. I replaced the harness ($70), now I have no power door locks from the door switch, the key fob, or the keyless entry. the security system works, the seat memory works, but no door locks. I have checked every fuse, been to the stealership twice, and they just want me to bring it in, $$$$$$. I suspect you have a bad wire in your door harness that is becoming separated when the door is shut. I would welcome any help on mine, but i am beginning to suspect the $150 smart junction box. i can't believe there is no fuse or weak link in the power door lock system. good luck!!!
Old 07-24-2014, 10:08 AM
1ATony's Avatar
PREMIUM SPONSOR
Check the wire harness that runs between the door and body of the truck for a broken or frayed wire. If there's a damaged wire, you should be able to repair it, or solder it back together and be back in business.
__________________
Like us on Facebook
Old 07-24-2014, 11:01 AM
LH rear is a new harness, to see if there is power to the switches do i have to remove door panels? Also, when you trigger the door switches, I can hear a click down by the SJB. Do you know if there is a relay or fuse specific to the power door locks that is kept secret from the owner of the vehicle?
Old 07-24-2014, 11:11 AM
Torklift Sheryl's Avatar
Torklift Sheryl Torklift Sheryl is offline
SPONSOR
Torklift Sheryl has a good reputation on FTE.Torklift Sheryl has a good reputation on FTE.
Welcome to FTE! Hopefully you'll find some answers here. Good luck!
Torklift Sheryl
__________________
Torklift International Towing, Suspension, Tie Downs, Steps
Call me direct: 1-800-246-8132
Visit our Blog: http://www.torklift.com/blog
Old 07-26-2014, 11:12 AM
does anbody know what powers the door locks? my 2009 f-250 power door locks won't communicate with the truck. when you operate the door switch, key fob, or keyless entry pad on door, there is click in the SJB (smart junction box) in the passenger foot well. Everything else on the truck works. Help!!!!!!!!!!!
2000 Crew Cab Drivers Side Door Lock Question stowbilly96 1999 to 2016 Super Duty 3 11-09-2016 01:47 PM
96 Crew Cab Driver rear door lock stuck down and locked SteveL53 Electrical Systems/Wiring 2 07-26-2016 09:53 AM
door locks going out scotttahoe 1999 - 2003 7.3L Power Stroke Diesel 18 01-22-2015 10:32 PM
Strange Door Lock Problems??? Roc53ky 1999 to 2016 Super Duty 0 10-27-2014 05:30 PM
ford f350 2003 crew cab power lock problems fruitcake1234 1999 to 2016 Super Duty 1 10-15-2013 07:04 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
