Broken exhaust manifold studs? If it's sucking air in, and yes, it can actually suck air into the exhaust under load, it'll throw the air-fuel ratio off according to the O2 sensor, and run way rich to make up for the extra oxygen.
Duh, don't know why I didn't think vacuum leak, good call DSN46
Thanks Krewat!
I just read my post again and I absolutely was not suggesting that it could not be the exhaust manifold (cause it very well could be).... I was just saying that the manifold was not the problem in my particular case.
Hope you understood what I meant...
