Who thinks my truck was wrecked by the PO? - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Old 07-20-2014, 12:27 PM
DanielT28's Avatar
DanielT28 DanielT28 is offline
DanielT28 is starting off with a positive reputation.
Had the truck 3 years or so. Few points point to this truck may have been wrecked or a project. Such as no rear cab bolts when I bought it. Rear seats are just like the fronts. There were no visors. And more stuff.
But my main thought is how the brake master cylinder sits up at a backward angle. What do you guys think ?
Old 07-20-2014, 04:00 PM
Diesel_Brad's Avatar
Diesel_Brad Diesel_Brad is offline
Diesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud of
That is show the master cylinder sits on all these trucks.
As for the front and rear seats being the same, OK. What is the big deal? Someone swapped out a 40-20-40. You should be happy with the upgrade
But the biggest thing you are missing, is the cab was NOT originally red!!!
Old 07-20-2014, 04:03 PM
DanielT28's Avatar
Yeah. I'm not in happy. I'm just curious. Lol.
But ya. Under the carpet in the cab it's white. And one fender is black. And the bed I took off was a lighter red
Old 07-20-2014, 06:32 PM
MOOSE_MACHINE's Avatar
MOOSE_MACHINE MOOSE_MACHINE is offline
MOOSE_MACHINE has a good reputation on FTE.MOOSE_MACHINE has a good reputation on FTE.
Are you sure that's how the all sit. I took a look at mine after reading this and it sits level to the fluid. Although I know mine was hit on the front left. But only hard enough to bend the bumper and wreck the fender. The rad support is all still original. Maybe mine is the efed up one
Old 07-20-2014, 06:35 PM
427 fordman's Avatar
427 fordman 427 fordman is offline
427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.
Mine tips slightly back, but not that drastic for sure.
Old 07-20-2014, 06:55 PM
The cab was originally white, And the red in these years was not clear coated and like to fade to Pink. So not uncommon to repaint it with clear coat.
Also the fender was black, big deal.
You have to remember, there trucks are 20 years old and ALOT can happen in those 20 years
Old 07-20-2014, 07:15 PM
^^^^^^x2. A good inspection prior to purchase can tell you a fair amount. When I bought mine I could tell by the lack of a ford emblem on the driver side fender, a new skirt that goes under the grill and the new bumper. The paint is fairly new but the passenger fender is rusty. If someone had reprinted it solely for looks they would have addressed that as well.
Old 07-20-2014, 08:06 PM
nateairman's Avatar
nateairman nateairman is online now
nateairman is gaining momentum as a positive member of FTE.
In my mind there are two kinds of wrecked.
Accident or neglect.
With these trucks your lucky to only have to deal with one.
My truck has had the bed swapped the core support redone. Now I have swapped fenders doors and have another cab waiting.
We all want the perfect truck but it is hard to come by. I am not sure how many km are on my truck but the Odo has been over 400 once with me and at least once prior.
Over all I am happy that it has all the parts mostly attached except for the rust situation.
Now if only I could take it all apart and make it new again!
Old 07-20-2014, 11:10 PM
DanielT28's Avatar
I was just curious as to what everyone thought. Don't bother me one bit. I've just questioned it since I bought it and thought I'd ask for opinion.
Keep in mind that I absolutely LOVE My 7.3 power stroke and wouldn't do anything to change it !
Old 07-20-2014, 11:53 PM
nateairman's Avatar
It does look a little extreme. Have taken the booster off to see if it had failed and the fire wall got pushed out from pushing the pedal hard? Just a thought
Old 07-21-2014, 12:22 PM
Nathan's got a good point. I think I read a thread about a weak spot in the firewall that would crack. Though I may be thinking of a different vehicle. Maybe this brings memories back of some of the gerus on here
Old 07-21-2014, 02:05 PM
DanielT28's Avatar
No I actually haven't taken it off before. In the 3 years I've owned it that's how it's sat the whole time. And I haven't had any problems with the brakes at all.
Would it be a good idea then to do so ?
Old 07-21-2014, 06:08 PM
These trucks did NOT have a problem cracking the firewall. But the 91 and older trucks did.
Also, I just looked at my 5 trucks and the angle of the master cyl is the same as yours
Old 07-21-2014, 06:14 PM
Quote:
There you go. I used to cruise the pre powerstroke forums. That must have been where I saw it
Old 07-21-2014, 11:10 PM
DanielT28's Avatar
I was never worried. Just bored so thought id ask !
'55 panel build sstephanuik 1948 - 1956 F1, F100 & Larger F-Series Trucks 146 02-16-2017 02:53 AM
Carburetor help Jsek 1957 - 1960 F100 & Larger F-Series Trucks 5 12-07-2016 09:42 PM
Springfield, MO Swap Meet bjmayberry2 1948 - 1956 F1, F100 & Larger F-Series Trucks 17 09-22-2016 11:40 PM
G'day to all from Australia. Big G71 New Member Introductions 3 10-08-2015 09:49 AM
1965 F-250 Gribbler101 1961 - 1966 F-100 & Larger F-Series Trucks 8 08-13-2015 08:49 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
