Fuel Tank Lock Rings - Ford Truck Enthusiasts Forums
Old 07-20-2014, 04:17 AM
Spktyr Spktyr is offline
Spktyr is gaining momentum as a positive member of FTE.Spktyr is gaining momentum as a positive member of FTE.
Working on the 95 truck down in my signature. It's got dual tanks; I am having to drop them to replace the 'showerhead' pickups. Looking to get the lock rings before I start work, but I am seeing multiple options listed on Rock Auto and other parts vendors' sites which seem to be mutually exclusive.
I am seeing listings for lock rings of 3 5/8" and 3 7/8" diameter, plus this 'universal' Dorman/Help kit with various sizes. Which lock ring size or kit should I get for my truck? Thanks.
Old 08-02-2014, 10:19 AM
Bump - anyone?
Old 08-02-2014, 11:30 AM
wtroger wtroger is offline
wtroger is gaining momentum as a positive member of FTE.wtroger is gaining momentum as a positive member of FTE.
I have never had to replace a steel lock ring. I use a brass drift and tap them around to get them off. A little pb blaster helps. Put them back on the same way. I just grease the o-ring to hold it in the groove. Plastic rings I use a big pair of channel locks.
Old 08-02-2014, 11:57 AM
GoinBoarding GoinBoarding is online now
GoinBoarding is gaining momentum as a positive member of FTE.
I've only replaced with a new pump & tank on a gas truck, and each time the tank included a new lock ring. Only advice I have is buy them both and just return whichever doesn't work--not very useful advice though. Hopefully someone happens to know.
Old 08-03-2014, 11:44 AM
dixie460's Avatar
dixie460 dixie460 is offline
dixie460 has a good reputation on FTE.dixie460 has a good reputation on FTE.dixie460 has a good reputation on FTE.
Just do what I do... buy ALL the parts that could possibly fit, and return the ones you don't use.
As for actually needing a lock ring... I ain't ever had to replace one yet either. They usually come right off with some gentle tapping and maybe a choice word or two.
Rear Fuel Tank Replacement Treacy 1987 - 1996 F150 & Larger F-Series Trucks 0 11-06-2016 07:53 PM
Warn locking hubs install problem wrdabney 1999 to 2016 Super Duty 18 10-07-2016 04:29 PM
Fuel tank sending unit lock ring jb10725 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 2 12-07-2014 05:20 PM
Fuel tank sending unit gasket PRUSue 1973 - 1979 F-100 & Larger F-Series Trucks 7 07-21-2014 07:39 AM
5R110 Bypass Filter Housing Modification Aerocell4x4 Clutch, Transmission, Differential, Axle & Transfer Case 0 10-27-2008 10:22 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
