Wheels and Tires - Purchasing...Need Info on sizes and types
Southwest Wheel Company - Alcoa Wheel Sets
Truck Chassis Accessories - 167041 - Alcoa Aluminum Single Wheel - 16" x 7", 8 Lug
Amazon.com: Alcoa 16x7" Aluminum Trailer Wheel with Accesories (1/2" Studs): Automotive
Nope, I guess that price wasn't out of line after all.
Call southwest wheel. They do not stock them any longer. I talked to them 2 years ago too
on
the more aggressive the tread,the higher the rolling resistance and lower the fuel economy,so tires in type and size are just like all the mods you do to your truck.they have pro's and cons.you need to pick what you think will suit your needs the best.
that said,the slightly better traction ltx a/t2 looks as if economy doesn't drop too much,but these prices are killer and i plan on a tru-trac for the rear this summer/fall too cus this dually sucks for traction anyway.
let 'er roll.chain up for traction.
I am getting asset off of a 97 that were taken off in 97 and have not seen the light of day since. I an getting them and the tires for $225.
keep on eye on crags list.
So, found a set of American Racing wheels that I think may look nice on the OBS trucks. Check out the link and let me know what you think.....
I am thinking the model #AR 236882
Tires will be...Michelin LTX M/S2 265/75R/16 Load range E
American Racing - Wheels
Then there's the Eagle Alloys.....
http://www.aewheel.com/wheels_detail...d=1947&cat=472
Series 058 Specifications - RWD/SUV Truck - Eagle Alloy Wheels
Between the two, which do you prefer on our OBS trucks? I lean towards the slotted ones (American Racing) as opposed to the one with holes (Eagle)
Also, theer are many specs to chose from......so they fit as close to stock as possible, which are the preferred specs....backspacing and offset?
This is the one called for on their website for my truck......
http://www.americanracing.com/wheels...el=F-350%20SRW
#29
Well, after going back and forth, the Eagle Alloys have won me over. Now, which ones (specs) will fit my 2WD truck....Backspace and offset?
