Found a little ball in the fuel bowl - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Old 07-20-2014, 12:51 AM
nateairman's Avatar
nateairman nateairman is offline
nateairman is gaining momentum as a positive member of FTE.
As the title says. I found a ball in the fuel bowl. The truck has been apart for six months for a bit of work. I removed the fuel bowl to get at a few things. When I removed the filter to refill it a ball came up outside the filter and fell back in to the bottom. I have no idea what or where it came from. A quick glance is all I had. 1/4" diameter or so.
The truck did start up. I have not checked fuel pressure at idle but will tomorrow when I find the gauge.
Old 07-20-2014, 12:55 AM
Chris56ford's Avatar
Chris56ford Chris56ford is offline
lost
Chris56ford is gaining momentum as a positive member of FTE.
Sounds like the check ball that goes behind the screen in the regulator, is your screen still there?
Old 07-20-2014, 01:02 AM
nateairman's Avatar
Quote:
It seemed to be there. I looked in the side and it seemed to be. I did pull the regulator off to clean the screen. That was out of the truck on the bench. Any one have a pic of the ball and screen combo?
Old 07-20-2014, 01:53 AM
fordpride's Avatar
fordpride fordpride is offline
fordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant future
Old 07-20-2014, 10:43 AM
nateairman's Avatar
Thanks ford pride. It looks like i will be pulling it a part again. Unfortunately the ball does not float and I will have to disassemble the bowl in the truck.
Won't start after changing out fuel pump finerant 1994.5 - 1997 7.3L Power Stroke Diesel 8 04-16-2015 01:17 PM
oil in the fuel filter bowl skippy73 1999 - 2003 7.3L Power Stroke Diesel 9 03-30-2015 04:58 PM
urgent - am i missing something - urgent austf350 1994.5 - 1997 7.3L Power Stroke Diesel 8 05-15-2014 07:18 AM
Fuel filter light????? plgebbia 1994.5 - 1997 7.3L Power Stroke Diesel 9 07-28-2010 11:07 PM
2001 F350 Gelled this week. Want to test bowl heater. dn29626 1999 - 2003 7.3L Power Stroke Diesel 13 01-13-2010 07:44 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
