HELP!!!! NO THROTTLE - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Old 07-19-2014, 11:56 PM
aaronsilva90 aaronsilva90 is offline
aaronsilva90 is starting off with a positive reputation.
I have a 1997 ford f250 diesel 7.3 with about 290k for miles I needed to replace my throttle control sensor (TPS) due to a very low idle postion so I did it was fairly easy and quick after install of the new TPS and TPS connecter the truck idle fine but the throttle is not responding whitch it did before install I'm not sure what I did wrong any ideas ?? The IVS seems to be working fine the TPS and IVS are receivin power as well
Old 07-20-2014, 12:14 AM
ReBilld's Avatar
ReBilld ReBilld is offline
ReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to behold
Make sure that the blade on the end of the shaft is in the slot on the back of the TPS. you have to put the TPS on that blade then rotate it to line the bolt holes up.
Old 07-20-2014, 12:30 AM
I have checked the blade and it is set in the slot also the RPMS did move from about 400rpms to 800rpms after the new install
Old 07-20-2014, 12:40 AM
I have also checked all the fuses under the dash and hood all seem to be working
Old 07-20-2014, 12:44 AM
fordpride's Avatar
fordpride fordpride is online now
fordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant future
What was the part # of the TPS you used ?
Kinda odd your rpm changed since the TPS doesn't control the idle.
Old 07-20-2014, 01:08 AM
Connecter # pt5777 made by BWD
TPS made by MPI # 2-99035
Old 07-20-2014, 01:50 AM
fordpride's Avatar
Old 07-21-2014, 01:42 AM
I will look in to using the sensor you found if this doesn't work though I'm out of ideas ... is there anything else that could cause this issue ??..
Thank you for your advice I really appreciate it
Old 07-21-2014, 01:46 AM
glovemeister glovemeister is offline
glovemeister is gaining momentum as a positive member of FTE.glovemeister is gaining momentum as a positive member of FTE.
My money is on the fact that you ordered a TPS. There is no such thing on a diesel. It is referred to as an APS, or Accelerator Pedal Position Sensor. Coupled with the fact that you had to change connectors (APS sensors are directly bolt in/plug and play, with factory wiring, you never have to change connectors). Between the sensor and your connector splice, I'd bet the wiring is wrong and also the sensor is wrong.
Before I messed with the wiring I would install the correct sensor, and then if it still doesn't work, investigate your wiring.
Throttle cutting out at low RPMS TPS & IVS syahj04 1999 - 2003 7.3L Power Stroke Diesel 10 02-09-2015 06:01 AM
sudden loss of throttle Peterbilt376x 1999 - 2003 7.3L Power Stroke Diesel 6 12-03-2014 08:10 PM
aps/tps voltage? streece 1994.5 - 1997 7.3L Power Stroke Diesel 4 03-12-2014 09:15 AM
TPS - Throttle Position Sensor FYI PaysonPSD 1999 - 2003 7.3L Power Stroke Diesel 72 10-23-2013 04:42 PM
Is it necessary to adjust TPS? gmk035 1987 - 1996 F150 & Larger F-Series Trucks 3 03-14-2010 07:09 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
