2015 exhaust brake
#46
2015 F-450 Chassis Cab Lariat
As you all my have heard, the chassis cab has the lower HP/ Torque tuning (330hp/ 660 Ft lb. torque, when I ordered it I assumed it would have the 465/ 880 ft. lb tuning.. Nope..! I read about the 80 mph speed limiter as optional.. Nope..! it has it as well, I also though the Turbo exhaust brake would be included considering it is a commercial truck... Nope..! I did however notice behind the driver’s side 12V power socket panel there is the wiring harness and plug for the exhaust brake.. Is it possible that if I were to order the 12V socket panel with the exhaust brake switch and plugged it in that the brake will work..? Or would I have to take it to the dealer and have the eeprom flashed..? I had the turbo brake on my 06 duramax (LBZ) and it worked awesome. I liked the way it came on automatically when in tow/ haul mode and you lifted on the accelerator. Is there a way to enable the exhaust brake if not factory equipt..?
#49
#50
on
When you are towing, just press the button after you start the engine and the ECU will automatically engage the brake and release it as needed. It is most evident when you are in Tow/Haul mode with the transmission. I don't know if there is a way to manually engage and release. This is the way I do it anyway...
Yes the manual is very vague on this..
#51
Tow/haul turns the brake on automatically. If you are not in tow/haul and want to engage the brake, press the fart button. I will pop it on when some idiot decides to slam their brakes on in front of me and not use their turn signal. It's the fart button or a Ford emblem up their a..... It seems to work well in their favor.
#52
Tow Haul worked as usual.
Additional braking and and engine noise was obvious when the Engine Brake was electronically engaged with the dash button while in Tow Haul mode.
#53
on
The exhaust brake button on my 2015 toggles the EB ON and another press toggles it OFF. It is not a momentary contact where the exhaust brake is engaged only when pressing the button.
Also, there is very little racket / noise produced by the EB on my truck.. You can heard the muffled pffft pffft pffft as the EB kicks in..
#55
Yep, i read that very note and that was the most information i could find.Read all of the other provided information. Been a diesel owner for 22 years and farm diesel before that. Still wasn't provided enough good information to fully understand when to engage the engine brake.
So, it seems that it does not turn on automatically when the tow haul is selected and i need to engage the switch when i am ready to begin towing to use this feature when slowing/stopping. Otherwise, there is no other driver participation in the actuation of the device. It isn't going to hurt the vehicle if it is driven with the device selected whether towing or not? at what speeds does it work?
No, i am not planning on doing my daily driving with the engine brake on and i am preparing to tow my tt in a week then my 6x12 with my harley in it in 2 weeks. trying to get more acquainted with my equipment.
thanks for help fells, i am getting a little more info as we go!
#56
on
This truck is truly impressive.
#57
Now I'm bummed.
I'm not too concerned about the speed limiter though.
#58
The DRW F-450 Pickups get it.. Including the 440hp, 860 Ft Lb. I heard if the Chassis Cab got the same equipment the Motor and Transmissions might not be able to handle the constant pounding. I'm toting 15,500 lbs. 24/7 towing nothing.. I was sure disappointed to find I will have to live with 330 hp, 660 Ft. lbs. No Exhaust Brake (unless someone can figure out how or if it can be hooked up like my 06 LBZ Duramax) and the 80mph speed limiter. I get the safety part of it but sometimes it might take more than 80 mph to pass a vehicle.
Just Say-in
Just Say-in
#59
Also, it better not void the warranty when I put a true aftermarket exhaust brake on my truck.
#60
Not likely.. Ford says..
"Even though the pickup and the dyno-cert share the same block, they are certified completely differently. The ratings of the chassis cabs fall into a whole different category based on GVWR. It’s a different engine, different turbo charger, different after-treatment, different*exhaust system, different EGR system, different*torque converter*- same block but different engine altogether." I can say that mine handles the LACK of power pretty well.. I still have this 2nd gear driveline vibration that goes from the top of 1st gear all through 2nd gear..? Two Ford techs say it's normal..? So I'm going forward with my Kelderman F-450/550 Cab and Chassis 4-Link Rear & Front Air Suspension with auto ride. This should take care of the stiff as hell ride.. My install appt is on the 4th.. I'm pretty stoked..
