Whats a unknown condition 427 worth to you?
Old 07-23-2014, 09:02 PM
lurch460's Avatar
lurch460
lurch460 is offline
Well he came in today and said he is sure its a 429 not 427 not worth anything to me.
Old 07-24-2014, 06:16 AM
jowilker's Avatar
jowilker
jowilker is offline
A quick check, 429 = bell top flat with 7.5" bolt hole spread, or FE round top bell.
John
Old 07-26-2014, 12:41 PM
baddad457's Avatar
baddad457
baddad457 is offline
Originally Posted by Krewat
Sleeving is different than overboring. If the sleeve is thick enough, you don't really need to care about the strength of the remaining cast cylinder.
You do when it's a dry sleeve installation. And you have to have something left at the bottom to support the sleeve, that's still connected to the block structure.
Old 07-26-2014, 12:43 PM
baddad457's Avatar
baddad457
For sure not worth a grand, unless its a CJ/SCJ motor, or a Boss nine. Might want to take a look at it anyway to see if it's worth investing in
Old 09-09-2014, 10:46 AM
jrods2's Avatar
jrods2
jrods2 is offline
fe motors
excuse me for being blunt but the hype around the fe is cr@p. there's 1000's of them out there & everybody thinks they are worth GOLD. I have one. I just keep shopping around and sooner or later you find the realist that will sell you what you need or want for a reasonable price, anything over $500 is a wast of money. I have a 390 with aftermarket parts with a Paxton super charger. If you can't find what you want the aftermarket is willing to set you up with a fe that will kick just about anything on the street. good luck. I've got $3500 in mine and just as long as I keep it under 6k rpm I'm good for a long time. I'd never build another one, I'd go with a 460, Its cheaper and a hell of a lot more power.
Old 09-09-2014, 10:41 PM
85e150's Avatar
85e150
85e150 is online now
Received 1,595 Likes on 1,300 Posts
Well, to be blunt if you knew anything about 427s you would not lump them in with 390s, and you would know your pillow barge 460 was always a comatose slug in factory applications, while the 427 was built to win races from the local drag strip to Le Mans. No one collects 460s.
Old 09-10-2014, 01:33 PM
baddad457's Avatar
baddad457
Well, around here I've seen quite a few 460 collectors. BUT, once they've shelled out the $$$$ for them, they have a HARD time selling them. Unless it's to the local scrap yard
Old 09-10-2014, 07:32 PM
1972RedNeck's Avatar
1972RedNeck
1972RedNeck is offline
To a normal person this may be the case.
I despise all gassers - except FE's. There is just something about an FE that turns my crank - the sound, the torque, the look, and the hernias caused by the intake manifold. It is irresistible.
I have always been a Cummins fan and have combined Cumminses and Fords to make great vehicles, but when it came time to put a new engine in my '66, I just couldn't resist the call of the FE.
Old 09-10-2014, 09:38 PM
baddad457's Avatar
baddad457
The sound ? I don't understand that part. There are two basic firing orders for V8's that could (possibly) change the sound. As for Diesels, gimme me a 3406 Cat or an old big cam 400 Cummins at 2600 rpms with straight pipes
Old 09-11-2014, 09:19 PM
1972RedNeck
Does a 302 and a 460 sound the same? I haven't heard any that sound even close to the same.
Old 09-13-2014, 09:02 AM
krewat's Avatar
krewat
krewat is offline
Site Administrator
Depends on the 302 - 302HO had a different firing order than the "regular" 302, same as the 351W and 351M
From the front of the engine, the two different firing orders are:
1-5-4-2-6-3-7-8 - L-R-L-L-R-L-R-R
1-3-7-2-6-5-4-8 - L-L-R-L-R-R-L-R
In reality, the left-right order is the same, just 180 degrees out of phase off (when you consider the timing cycle is 720 degrees).
So, doesn't really explain the difference. Cam, headers, bore size, all sorts of things make different engines sound different. Like apples and oranges, really
Old 09-13-2014, 11:22 AM
baddad457's Avatar
baddad457
Well it's not the firing order that you think causes the difference. I've had people say my 331 sounded like a big block. But it's not.
  #28
Old 09-13-2014, 10:42 PM
1972RedNeck
My point exactly.
helifixer
02-13-2013 08:16 AM
68 f250
04-12-2012 09:27 PM
JesusRocks
05-23-2009 07:38 AM
MER
12-15-2008 03:02 PM
68torino
02-11-2004 01:26 PM
Quick Reply: Whats a unknown condition 427 worth to you?
