Need new radiator for 49 F6 V8 - Ford Truck Enthusiasts Forums
Old 07-19-2014, 09:17 PM
flipklos flipklos is offline
flipklos is gaining momentum as a positive member of FTE.
Any one know of a good usable replacement radiator for the flathead for a 49 F6? Budget is a bit of an issue. Not realy interested in recoring it as it is about $400 to have that done...........
Old 07-20-2014, 02:29 PM
bobbytnm's Avatar
bobbytnm bobbytnm is offline
Roast em' if you got 'em
bobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud of
Its going to be a bit difficult since the V8 has to inlets and outlets. Anything from a newer, non flat head vehicle is only going o have one inlet and one outlet.
You might be stuck with recoring or finding a decent used one
Good luck
Bobby
Old 07-20-2014, 07:23 PM
harleymsn's Avatar
harleymsn harleymsn is offline
harleymsn is a name known to allharleymsn is a name known to allharleymsn is a name known to allharleymsn is a name known to allharleymsn is a name known to allharleymsn is a name known to all
Here's a new aluminum, I don't know anything about these folks and their products though.
https://www.radiatorexpress.com/prod...MDPRoCZYjw_wcB
Old 07-21-2014, 01:22 AM
Will look into it on payday if my head checks out good!
Old 07-21-2014, 08:56 AM
bmoran4's Avatar
bmoran4 bmoran4 is offline
bmoran4 is gaining momentum as a positive member of FTE.
From my expereince, recoring is the same price range as the cheaper new flathead radiators (~$400). With the new radiators, they don't always come with the mounting holes in the right spot, fit exactly etc, but if you get yours recored, you eliminate a lot of those uncertanties while retaining the stock look. Plus you will build a relationship with your local radiator pro who could help you down the road should there be an issue. They can also help you boil out your fuel tank etc.
Old 07-21-2014, 06:55 PM
The local radiator guy is famous for boiling them out, repainting them, and returning a leaky radiator.
I would have to take half a day off of work and drive 50 miles four times to get it repaired.
I can try to get a quote later this week. I do agree with your sentiments however.
I am not quite sure that a F1 or F2 radiator is as large as a F6s. I do belive that it would work if need be.
Old 07-21-2014, 08:24 PM
harleymsn's Avatar
Although there was an optional extra cooling radiator available,(1RT 8005B) the standard radiator was the same for F1-F6 (1RT 8005A)
Old 07-21-2014, 09:46 PM
Measured the core area tonight got about 21"x21" for the core itself. Going to try and call to get some quotes in the next few days.
Old 08-14-2014, 11:11 PM
Installed the radiator suggested by harlymsn. Fit like a glove. Kinda weird though it came with an 18psi radiator cap. Will head to napa and see if I can get a 7 or 10psi one tomorrow. Going to install my cylinder head tomorrow afternoon or early Saturday. Will let you know how it works.
What size Radiator in 49 F1 kens65fb 1948 - 1956 F1, F100 & Larger F-Series Trucks 5 01-07-2017 01:31 PM
Which radiator do I have? phoskins 1987 - 1996 F150 & Larger F-Series Trucks 2 01-12-2015 08:20 PM
Radiator Repair kosovich@nqks 1987 - 1996 F150 & Larger F-Series Trucks 17 07-11-2014 03:56 PM
Fan Shroud Necromancer 1987 - 1996 F150 & Larger F-Series Trucks 2 05-27-2014 02:06 PM
1976 Ford F250 4.9 300 inline 6 ChrisBishop 1973 - 1979 F-100 & Larger F-Series Trucks 1 09-27-2013 03:21 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
