E4OD shifts hard - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
E4OD shifts hard
Old 07-19-2014, 08:49 PM
Bigal700 Bigal700 is offline
Bigal700 is starting off with a positive reputation.
E4OD shifts hard
I put a used E4OD in my truck that the guy told me had 3000 miles on a rebuild but it shifts hard like it just drops into gear it isn't nice at all what can be causing this?
Old 07-19-2014, 10:07 PM
fordpride's Avatar
fordpride fordpride is offline
fordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant future
Is the OD light flashing ?
Is it a hard shift or a firm shift ?
Old 07-19-2014, 10:32 PM
OldWoodsDiesel's Avatar
OldWoodsDiesel OldWoodsDiesel is offline
OldWoodsDiesel is gaining momentum as a positive member of FTE.
before i swapped to the zf5 my truck would shift hard whenever it rained. turned out the sealing gasket in the connector on the RH side of the tranny was bad and letting water in. you might check and make sure you connector there is seated right. it looked like it was quite easy to get that seal all jammed up inside so that the pins didnt engage right.
just a thought.
Old 07-19-2014, 11:25 PM
It dose it all the time unless u really get on it and it is firm but firmer then it should be
Old 07-19-2014, 11:42 PM
fordpride's Avatar
It could just have a shift kit in it
Old 07-20-2014, 12:10 AM
aaronsilva90 aaronsilva90 is offline
aaronsilva90 is starting off with a positive reputation.
check this
Have you looked in to checking your (TPS) throttle postion sensor it could be going out also what RPMS at you running at an idle ??
Old 07-20-2014, 09:02 AM
Mark Kovalsky's Avatar
Mark Kovalsky Mark Kovalsky is offline
Mark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputation
Quote:
Does the OD OFF light work when you press the button? Does the light flash?
Old 07-20-2014, 02:19 PM
The OD light isn't flashing or anything and the guy told me he built it back to stock and ill have to check but my old transmission never shifted firm even when i could only go 30 mph i put transmission additive in it then it shifted nice for a little bit but then it came back and the transmission oil seems fine
Old 07-21-2014, 08:55 AM
OK, does the OD OFF light work when you press the button? I'm persistent, I will keep asking the same question over and over until I get an answer.
Old 07-21-2014, 10:20 PM
The light works fine
Old 07-22-2014, 11:42 AM
Since the light isn't flashing this means there are no codes stored. That means there is something mechanical causing the harsh shifts. Most likely it has a shift kit that is doing it.
Old 07-22-2014, 12:08 PM
Bob Cat Bob Cat is offline
Bob Cat is starting off with a positive reputation.
My E4OD has a similar problem however it has been rebuilt and believe it has a shift kit in it.
E4od Hard shift when tranny is warm Ceaumar 1987 - 1996 F150 & Larger F-Series Trucks 4 05-12-2016 03:42 PM
E4OD delay into drive stevenjf88 1987 - 1996 F150 & Larger F-Series Trucks 3 10-28-2015 11:39 PM
96 F-150 E4OD hard down shift max harris 1987 - 1996 F150 & Larger F-Series Trucks 0 10-03-2015 12:04 PM
E4OD problems JimmyO1331 1978 - 1996 Big Bronco 4 10-22-2014 05:24 PM
E4od/4r100 Mikemusial 1994.5 - 1997 7.3L Power Stroke Diesel 2 09-17-2014 10:43 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
