New Glass, New Seals and Felts...Woohoo - Ford Truck Enthusiasts Forums
Old 07-19-2014, 07:36 PM
Doc's Avatar
Doc Doc is offline
Doc has much to be proud ofDoc has much to be proud ofDoc has much to be proud ofDoc has much to be proud ofDoc has much to be proud ofDoc has much to be proud ofDoc has much to be proud ofDoc has much to be proud of
I now have a new windshield (actually replaced it before the Truckstock trip), a new rear window, new side and vent windows, new window seals and felts, and new division bars for the side windows. Everything looks MUCH better and much more airtight. No more rattle, rattle everywhere. And I guess I'm now part of the club that hates those stupid little metal clips for the anti-rattle felts. I also replaced the lift channels for the side windows. I really had to "persuade" that glass, channel rubber, and the channel itself to come together with a rubber mallet. Kind of makes you nervous. The most time consuming part was disassembling the vent windows so that the new rubber seal could be installed between the outer and inner frames.
Old 07-19-2014, 08:44 PM
Marauder2004's Avatar
Marauder2004 Marauder2004 is offline
Marauder2004 has a good reputation on FTE.Marauder2004 has a good reputation on FTE.
Congratulations on your success with the seals! I was dreading it and looking back it was more simple than I expected, except for installing the anti-rattle clips!
Old 07-19-2014, 08:54 PM
raytasch's Avatar
raytasch raytasch is online now
Old guy with old toys
raytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant future
Yep, sure makes a difference, doesn't it.
Old 07-19-2014, 09:21 PM
Doc's Avatar
Doc Doc is offline
Quote:
Yes it does. But not as much of a difference as that engine under the hood. Thanks again, Ray.
Old 07-20-2014, 09:13 AM
Schuyles's Avatar
Schuyles Schuyles is offline
Schuyles has a great reputation on FTE.Schuyles has a great reputation on FTE.Schuyles has a great reputation on FTE.Schuyles has a great reputation on FTE.
It's good to hear it made a noticeable difference! That's one of the things I keep putting off on my '65, and I just know once I do it I'll wonder what took me so long...
Old 07-20-2014, 09:47 AM
Doc's Avatar
Doc Doc is offline
Quote:
It makes a huge difference. The door feels "heavier" and more solid. I'm sure it will also make a huge difference in the winter.
Old 07-20-2014, 09:49 AM
Jolly Roger Joe's Avatar
Jolly Roger Joe Jolly Roger Joe is offline
Just another Joe
Jolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud of
That's cool!
I'm "looking forward" to this experience as well. But I have body work and paint to do first.
Old 08-14-2014, 05:04 PM
DW SD DW SD is offline
DW SD has a very good reputation on FTE.DW SD has a very good reputation on FTE.DW SD has a very good reputation on FTE.DW SD has a very good reputation on FTE.
I'm looking for some assistance in matching up these window seals. I bought some from The old ford supply in escondido and they looked nothing like what I have.
Anyone recognize these and know where I may buy another set?
See the attached photo.
Thanks!
Doug
Old 08-17-2014, 10:13 AM
Thanks!
Doug
Bump - anyone recognize these seals? I want to buy another pair to match. Thanks!
1950 door anti rattler's Skalywag 1948 - 1956 F1, F100 & Larger F-Series Trucks 1 07-09-2015 10:49 PM
51 F1 Vent Window Install ssg1957 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 07-02-2015 06:40 PM
Vent Window Retainer HELP!!!!!! 4 rings 1961 - 1966 F-100 & Larger F-Series Trucks 11 03-25-2015 01:12 AM
Division Bar and Window Channel Adjustments 66f100project 1961 - 1966 F-100 & Larger F-Series Trucks 8 09-21-2014 11:18 PM
Dennis Carpenter still the place for Rubber Parts? wavetrain75 1948 - 1956 F1, F100 & Larger F-Series Trucks 5 04-02-2013 03:42 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
