Code question
Old 07-20-2014, 06:00 PM
bigmacmondayf250's Avatar
bigmacmondayf250
bigmacmondayf250 is offline
Originally Posted by Tigauto
Sorry brain fart, it did have heater circuit. I would start with basics mist water around intake and vacuum lines. The EGR allowed exhaust gas into the combustion chamber to reduce NOX by lowering combustion temp. This will cause a richer mixture in the cylinder. Check vacuum leaks, EGR for vacuum leaks and blockage. You can buy pads air injection by removing belt see if that make a difference,
Remove the belt? Wont work without the belt... No alternator, no water pump etc. Or am i reading what you mean wrong.
Old 07-20-2014, 06:37 PM
Tigauto's Avatar
Tigauto
Tigauto is offline
Is it all one belt or is there a different belt for the air pump. They use to run a small belt just for the air pump. Do you have a air pump? Do you have a 02 sensor before the cat and after the cat?
Old 07-20-2014, 07:11 PM
rla2005's Avatar
rla2005
rla2005 is online now
Received 1,157 Likes on 915 Posts
The OP's truck is a 1990, the O2 sensor is before the converter.
Old 07-20-2014, 08:44 PM
Tigauto's Avatar
Tigauto
Tigauto is offline
There is a listing for pre and post 02
Old 07-20-2014, 09:03 PM
rla2005's Avatar
rla2005
Wherever you found that listing it's wrong. Post converter O2 sensors were not used on this vintage truck until OBD-II was implemented. On gas engine trucks this is generally accepted as 1996.
Old 07-20-2014, 10:22 PM
bigmacmondayf250
Looks like its just one serpentine belt for the whole thing, not v belts. From what I can see when i was changing the o2 sensor is that there is just one, and its before the cat, on the H pipe.
Old 07-20-2014, 10:50 PM
bigmacmondayf250
What im trying to figure out is can EGR malfunctions cause a lean condition? I know i need to fix the egr stuff but im trying to take care of the lean issue first.
Old 07-21-2014, 07:27 AM
Tigauto's Avatar
Tigauto
Tigauto is offline
I would fix first what you have found wrong first. A lean code could be just about anything, vacuum leak, injector, air pump. Like I said the egr uses exhaust gas to lower box and combustion temp for NOX. It's makes the air fuel richer less air. For a lean code you have to have all component working. Did you mist some water to check for vacuum leaks. There are other products you can use but water is safer
Old 07-21-2014, 03:11 PM
bigmacmondayf250
Ok I will check all that out. Thanks a bunch for your help. I just want to make sure you're aware its not just the lean code being thrown, It actually is running lean which i determined from the spark plugs being white when i changed them out to put in some motorcrafts. What does the water mist do to help locate vacuum leaks? Just wanna make sure im doing it right.
Old 07-21-2014, 05:36 PM
danr1's Avatar
danr1
danr1 is offline
You guys talk about fuel pressure yet? if so I missed it, what is the fuel pressure reading?
Old 07-21-2014, 07:33 PM
Tigauto's Avatar
Tigauto
Tigauto is offline
Water
If you use a spray bottle go around the intake the water will seal the vacuum leak of a couple of seconds. I also great at finding bad wires, if just find it easier to fix what you have found wrong with the truck. Then move on to the next step, it's hard finding problems on the older trucks with out live data. Spray around intake, vacuum lines, EGR, make sure iac is working.
Old 07-21-2014, 08:25 PM
bigmacmondayf250
33 at idle after i replaced the regulator. was at like 74ish idle
  #28
Old 07-21-2014, 08:26 PM
bigmacmondayf250
Thanks man ill get to work and report back
  #29
Old 07-21-2014, 09:02 PM
danr1's Avatar
danr1
danr1 is offline
Oh yea sorry I did read that earlier on in the thread.
+1 with Conanski suggestion.
Disconnect the AIR hose from the AIR pump so that secondary air is bypassed to atmosphere during test, run the KOER test again see if code 41 disappears.
Should able to disconnect and plug the vac line to the diverter valve but that may be the sourse of the problem. Failure of the valve, its stuck, or someone rerouted vacuum lines as so it always has vac to it even when shouldn't have. Secondary air dumped to atmosphere = no vacuum supplied to the diverter valve.
Disconnecting the hose at the pump itself ensures that no air is delivered to the engine for accurate test result.
If code 41 disappears hose disconnected from pump the secondary air system is source of the problem know to look to it find fault.
If code 41 remains it is not the problem, reconnect hose move on.
  #30
Old 07-21-2014, 10:10 PM
bigmacmondayf250
Makes allot of sense, thanks man! I will do that in the morning and post the results.
Quick Reply: Code question
