what year 302 do I have
1975 is when the SBF engines got the smaller plugs. If you have a 302 that runs better then your 351 then it more than likely been modded. And how did you efi an early block there are some differences that make putting efi on an early block a bit challenging. You sure you don't have another 351.
Yes im sure its a 302 by the intakes I put on, and yes the old 351 was worn out but I didn't figure it was as bad as it was, I put a lot of work into the motor to convert it to to efi, had to get all new intakes, timing cover, and all that stuff. My uncle did say this motor did havrr aftermarket pistons in it, and by power I mean the truck can do burn outs for 50 yards without brake stand. I am very pleased with it.
lariat87
32
01-26-2007 05:57 PM
Soonerz75
05-10-2004 08:48 PM
