1951 Ford F 6 runs wide open
I bought a 1951 Ford F6 with a 254 flathead 6 cylinder engine and vacuum 2 speed rear axle that has been setting for over 15 year In pole barn. today I was able to get it fired up but it runs wide open throttle. This has and 897 holley carburetor on it and the throttle blade is shut down. I dont know much about the holley but seems strange that it starts right up but revs instantly. I just want to make sure its not something simple before tring to rebuild the carb. I also wonder if a carb kit is available for the 897 holley. Any help is appreciated.
I will try it, its strange to me, out of all the cars, truck and tractors that I have dragged out of barns, fence rows, I have never seen one rev wide open, usually they wont idle or wont run at all.
Does the butterfly in the throttle open and close? Check for that return spring. If the throttle shaft/butterfly is stuck, it must be stuck wide open. If it's closed against the throttle stop it should run at an idle. Hmmmm strange. Are you using the choke? That is tied into some throttle advance when the choke is shut.(pulled out). Great that you got it running though.
quakerj
11-12-2014 04:02 PM
quakerj
08-14-2013 03:13 PM
carpenter547
23
12-12-2009 06:32 PM
