View Poll Results: What year truck do you have with a leaky radiator
2011
17
70.83%
2012
25.00%
2013
4.17%
2014
0%
2015
0%
2016
0%
Voters: 24. You may not vote on this poll
2011 up - Radiator Leaks - POLL & Counts
Old 07-19-2014, 05:44 PM
Big-Foot's Avatar
Big-Foot
Big-Foot is offline
Arrow 2011 up - Radiator Leaks - POLL & Counts
So lets get a tally on the radiator problems on the 2011-2012-2013-2014-2015+ PSD Super Duty trucks..
I added a 2016 so the poll will still be good a couple years from now - please do not use that field unless you happen to have a 2016 with a radiator leak..
Old 07-19-2014, 05:47 PM
ruschejj's Avatar
ruschejj
ruschejj is offline
You technically could go back to 2008.
I had 3 radiators in my 2008
2 in my 2011.
Old 07-19-2014, 06:30 PM
wtrlogd's Avatar
wtrlogd
wtrlogd is offline
Mine has the slow drip in the spot usually mentioned (lwr-LH). It hasn't gotten better or worse over the last 100K+ miles though. Uses about a quart every 10K or so.
I plan to just keep watching it, unless it gets worse, can't justify the expense of a replacement.
Old 07-19-2014, 10:29 PM
azking_Ranch's Avatar
azking_Ranch
azking_Ranch is offline
MY 2011 no leaks yet.
Old 07-20-2014, 12:03 AM
sledhead_24_7's Avatar
sledhead_24_7
sledhead_24_7 is offline
I can't vote in the poll since my 2011 had zero radiator leaks in the 80,000 miles I owned it.
Not helpful for finding out how many had issues, just thought it might help to say not all had radiator issues.
But on a side not I did have turbo problems. So..... That might count right?😉
Old 07-20-2014, 12:06 AM
WildWildWest's Avatar
WildWildWest
WildWildWest is offline
Perhaps you should add one for NO leaks.
2011 - no leaks at all in radiator since new. 110,000 miles.
Old 07-20-2014, 06:01 AM
senix's Avatar
senix
senix is online now
Received 1,416 Likes on 1,011 Posts
no leaks in my 08 and so far no leaks in my almost 1 year old 13.
Old 07-20-2014, 08:53 AM
rob17's Avatar
rob17
rob17 is offline
Ditto.
Rob
Old 07-20-2014, 09:25 AM
Bigfootgrey's Avatar
Bigfootgrey
Bigfootgrey is offline
No leaks here!
Old 07-20-2014, 09:27 AM
rtazz17's Avatar
rtazz17
rtazz17 is offline
Yeah if possible add a no leak option.I would be interested in the leak to no leak ratio on the forum.Over all I'm GUESSING its very small percentage.Maybe not.
Mine 2011-no leaks
Old 07-20-2014, 10:55 AM
WABowHunter's Avatar
WABowHunter
WABowHunter is offline
2012 F350 6.7L CCLB - just developed a slow leak at 38,800 miles on the driver's side next to the radiator drain petcock. Taking it in this week as I have coverage until 125,000 miles.
Old 07-20-2014, 11:23 AM
vermilian's Avatar
vermilian
vermilian is offline
Had a leak on my 2011 so they replaced the rad. Then about a week later noticed another leak and this time it was the inter cooler.
....also as a side note, already had 2 egr coolers and an egr valve replaced. -_-
Old 07-20-2014, 11:31 AM
Glockin' Bob's Avatar
Glockin' Bob
Glockin' Bob is offline
No leak yet on my 2011.
Old 07-20-2014, 12:41 PM
SavageNFS's Avatar
SavageNFS
SavageNFS is offline
Received 7,068 Likes on 2,217 Posts
leaked at 65K or so...'11
Old 07-20-2014, 12:45 PM
2ndStroke's Avatar
2ndStroke
2ndStroke is offline
No leak here * knock on wood*
Quick Reply: 2011 up - Radiator Leaks - POLL & Counts
