Steering Stabilizer Question
Hello Folks, new diesel Ford owner here. I purchased the truck from a used car lot about 3 months ago and after driving for a few thousand miles I am feeling a slight wobble after hitting a bump in the road. Here is my truck set up;
- 2011 Ford Lariat F250 4X4 FX4 6.7 ltr
- 67400 miles
- Tires stock and great tread
- Rancho steering stabilizer kit
- Rancho Shocks
- Rear air bags
It does appear one of the rancho stabilizer dampers is leaking slightly. Why would the previous owner install a rancho stabilizer kit? Is it because of the rear air bags? I am not sure which direction to go here so all input is greatly appreciated and thank you in advance.
- 67400 miles
- Rancho Shocks
- Rear air bags
I had a similar issue of sorts with a 2012 f350 CC DRW off a Ford used lot. My cure was add a HD dampener, drop tire psi 45 to 60( settled on 60) and had a good shop align the front. Fixed me up fine.
What tires are you running? Max cold load and psi is? My front end weighed 4,960 or 2,480 per front tire....well below max load and psi. I dropped the psi to let the tires absorb some of the road shock. It made a difference.
I think what you are feeling in the steering is what many describe as the death wobble. It seems to be inherent to these trucks and becomes worse when the trucks are lifted.
My 2012 has had it since new and so far is the primary complaint I have with this p/u.
I was attempting to install a ProComp Pro Runner dual stabilizer today and the instructions say removal of the OEM stabilizer is optional, this probably explains why it was left on your truck.
on
The previous owner put that kit on to help counter the effects of the steering wheel shake/wobble when hitting sharp edge bumps. I did this to my 2012 superduty shortly after buying it new and it helped a lot. If your are leaking, replace them and enjoy lees wheel shake. I know have 3 like you.
The truck drives fine, no issues with alignment however tire pressure at specs. When hitting a rough spot in the road I get the suttle shake of the wheel. I just don't have a clue why there are 3 steering stabilizers. I figured the experienced crew here could shed some light.
As to alignment, I was not concerned with toe-in etc but I wanted to be dead certain all steering components were spec and tight(box, tie rod ends, etc) and not contributing to the problem. I was also at max cold psi which did not help.
For me, I made sure the front end was not worn from previous(owner)wobble, added a HD dampener and addressed tire psi. That eliminated my front end issue.
Bottom Line
Thanks for the help guys for this further reiterates what I was thinking but not 100% certain which direction I should take this. Bottom line;
- Keep the rancho damper stabilizer kit in conjunction with the stock one
- change the leaking rancho stabilizer damper
- drop tire air pressure from cold psi 70 to 45
- check front end alignment and steering components to insure no issues
I may just go ahead and replace the stock damper shock to the bilstein brand while I am under the frontend. Again thanks for all the input! You have provided much insight to the problem and for that I am grateful.
What is your tire rating and condition? Being a used truck, like mine, be sure and verify. My front end weighed 4960/2 or 2480 per tire.....much less than tire max rating so I dropped psi and settled on 60. The actual math calculation is from a formula used by another Forum member and smart guy. I will look for it.
Keep us posted.
Formula is below.
tire pressure is highly individual and subject to opinion.
https://www.ford-trucks.com/forums/1...-guys-run.html
assuming you have a crew cab diesel, you are a little over 4100 lbs on the front axle empty. your tires should be rated to 3195 @ 80psi, so you should be able to run all the way down to 51psi safely IMO.
4100/2 = 2050 lbs per tire
2050/3195*80=51.3 psi
sometimes lowering pressure can help quite a bit. if it were my truck, i wouldn't be afraid to try it.
Update
Hello Ford owners!
Update since the discussion in July. Changed the dual rancho stabilizer kit. While removing the old one I found the following issues;
- the existing rancho dual stabilizer U-Bolts were tach welded on the differential
- the stabilizers were mounted on the outside of the mounting center bracket
I replaced with the Rancho 9000 series dual kit and mounted per instructions and also dropped the front tire pressure to 55 psi. Since the change I am happy to report the wobble has disappeared.
The only concern at this point is the front shocks (Rancho) appear to have the front of the truck raised slightly. While driving at night, I periodically get the flash of bright lights from on coming drivers. It appears the previous owner may have done this when the air bags were installed on the front as to level out the truck. I will go back with stock shocks soon.
Thanks for your help and suggestions!
