aftermarket hitch for the X - Page 4 - Ford Truck Enthusiasts Forums
  #46
Old 08-04-2014, 07:59 PM
EXv10 EXv10 is offline
EXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputation
Quote:
Originally Posted by robert_l_ross View Post
Wisconsin Manufacturer of the Year Program...Wisconsin Manufacturer of the Year > Home
...so in other words, the Wisconsin Manufacturers & Commerce is a group sponsored in part by a lobbying group (https://www.wmc.org/) who's sole purpose is to promote commerce in Wisconsin. The award they won was one of nine issued this past year to businesses in Wisconsin.
The award simply means they were the best in Wisconsin - judged by what amounts to a chamber of commerce/lobbying group.
I'm sure they have a nice product (I have never owned a Curt hitch so I can't say if they are great or terrible), but I would also venture to say that the average Joe out there should not just consider an award such as this as meaning much. It's easy to get a lobbying group to give it's members an award...doesn't mean the product is somehow better than any other product out there.
I would agree with your statement:
...but I wouldn't pair that with
...and expect the award to bolster the argument. Now, if an independent group (oh, I don't know, maybe JD Powers or similar?) that had no stake in commerce in Wisconsin or better yet, evaluated companies OUTSIDE of Wisconsin (oh, I don't know, maybe the entire US?) was to issue an award, then maybe I'd put some weight to that statement.
But if they were as bad as everybody seems to claim in here there wouldn't even have made that list. That group has to have some kind pride or they would look bad................it would be Curt for me (but I don't need one).
  #47
Old 08-04-2014, 10:17 PM
Stewart_H's Avatar
Stewart_H Stewart_H is offline
The Nekkid Super Mod
Stewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputation
Quote:
Originally Posted by EXv10 View Post
Both of mine are stock and working fine but Warn is useless
Wow, so wrong it's ridiculous.
You may not have any use for Warn hubs, but they are far from useless.
If they were useless, they wouldn't work, and Warn hubs work quite well.
Stewart
  #48
Old 08-08-2014, 10:04 PM
mrfix mrfix is offline
mrfix is starting off with a positive reputation.
after looking for a good used hitch for my X for over a year I went to ford and was quoted $750.00 for a hitch for my 2001 X. Being a welder by trade I started looking for a multi fit class 5 hitch for an F350 to modify, I found a Reese class 5 multi fit at tractor supply for $189.00 and bought it. Got it home and dropped the fuel tank and mounted the hitch side plates using existing frame holes, when I installed the hitch beam onto the side plates I found the receiver tube to be pointing about 20 degrees to the ground, I cut the hitch beam in two places, 5" from each end plate, the beam is 3" x 1/4" thick round pipe, I then made two 1/4" X 3" long sleeves with 3" inside diameter that slipped over each end of the beam, I then bolted the hitch end plates to the side plates and jacked the hitch beam up into place sliding the sleeves over the cuts in the beam, doing this allowed me to turn the receiver tube to any angle I need. I set the receiver tube to the correct angle and tacked it in place, I removed the beam from the truck welded up the sleeves using 3/32 7018 welding rod, reinstalled the hitch beam and all is well. I now have a class 5, 12,000 pound capacity hitch that is made of thicker material than the OEM, mounts with larger bolts and is all around more rugged than the OEM with much better corrosion protection for less than the cost of the steel that is needed to fabricate it. The hitch height is correct as well as the angle of the receiver.
Just wanted to let you know that we can replace the hitch without being at mercy of ford.
Mrfix
  #49
Old 08-08-2014, 11:04 PM
Restlesswildman Restlesswildman is offline
Restlesswildman has a great reputation on FTE.Restlesswildman has a great reputation on FTE.Restlesswildman has a great reputation on FTE.Restlesswildman has a great reputation on FTE.Restlesswildman has a great reputation on FTE.Restlesswildman has a great reputation on FTE.
Pictures PLEASE!
  #50
Old 08-15-2014, 09:11 PM
Mrfix
  #51
Old 08-15-2014, 09:32 PM
Stewart
You often say I am wrong and it's always WOW! or CAN'T BELIEVE YOU SAD THAT! or something of that nature.
I was right about the rear sway bars and in most cases the Warns are bought needlessly. Nobody wants to admit it though. (a sticking dial is not a reason to throw money at the problem)
I was also right about the trans suddenly overheating in reverse and causing leakage.....not true.
Like I said before; as long as people keep buying things there will be someone there to sell it.
  #52
Old 08-15-2014, 09:37 PM
Bigpipes 35's Avatar
Bigpipes 35 Bigpipes 35 is offline
Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.
Ha, right about the rear swaybars, that's a good one..
  #53
Old 08-15-2014, 09:45 PM
Quote:
You could drag me back into the sway-bar saga but would you believe my educated analogies and assessments ?
  #54
Old 08-15-2014, 09:48 PM
You could drag me back into the sway-bar saga but would you believe my educated analogies?
You have no educated analogies, until you drive your particular EX with a rear sway bar and without a rear sway bar you have absolutely no education, Its just pointless dribble...
  #55
Old 08-15-2014, 09:56 PM
No it's not. After I made the assumptions I saw about 3 posts that agreed with me but that didn't confirm anything since the answer is just common sense to begin with, plus I cited personal observations on it to confirm my position on it.
  #56
Old 08-15-2014, 10:04 PM
mecdac's Avatar
mecdac mecdac is online now
If it flies, it dies
mecdac has a superb reputationmecdac has a superb reputationmecdac has a superb reputationmecdac has a superb reputationmecdac has a superb reputationmecdac has a superb reputationmecdac has a superb reputationmecdac has a superb reputationmecdac has a superb reputationmecdac has a superb reputationmecdac has a superb reputation
Quote:
Originally Posted by RigTrash601 View Post
Oh hell, here we go.......lol
^^^^ What he said. ^^^^
  #57
Old 08-16-2014, 12:05 AM
Stewart_H's Avatar
I say you're wrong when I KNOW you're wrong. I don't think it's very often (like you stated) , but rather, just on subjects you continue to argue about even when faced with facts.
Case in point:
Quote:
...and in most cases the Warns are bought needlessly.
You said, and I quote, that "Warns are useless." You didn't say they were needless, you said they were useless, and that's just plain wrong.
Warn hubs are far from useless. They work quite well. You posted bad information and I corrected it.
Nobody?? Jeez, you need to pay better attention. I not only agree with you when you say that, but I have often pointed people to your drill-a-small-hole fix that you came up with.
But that wasn't the assertion you made when I corrected you. You stated Warn hubs were useless and they aren't. They work and they work quite well.
No you aren't. Rear sway bars can help with Excursion Wander which means it helps with the ride. You don't have to tow or drive hard and fast to obtain a better ride by adding a rear sway bar.
Again, wrong. It is true. It's happened so many times, people have posted about the problem for years and Mark Kovalsky has explained why it happens.
Just because you refuse to acknowledge facts doesn't mean you're right. It just means (like I posted earlier) it's ridiculous.
Stewart
  #58
Old 08-16-2014, 01:49 AM
robert_l_ross's Avatar
robert_l_ross robert_l_ross is offline
robert_l_ross has a superb reputationrobert_l_ross has a superb reputationrobert_l_ross has a superb reputationrobert_l_ross has a superb reputationrobert_l_ross has a superb reputationrobert_l_ross has a superb reputationrobert_l_ross has a superb reputationrobert_l_ross has a superb reputationrobert_l_ross has a superb reputationrobert_l_ross has a superb reputationrobert_l_ross has a superb reputation
...according to who? You? According to you, of course you are always right. According to another few members? And what about the others that disagree with you...they are all wrong and you and your friends are all correct?
  #59
Old 08-16-2014, 01:51 AM
Oooo...three whole posts, huh?
And there is the key...you just said your "PERSONAL OBSERVATIONS". Observations aren't 'right' or 'wrong', so you should consider not claiming you are "right" and others are "wrong" since it's all just opinion.
  #60
Old 08-16-2014, 04:32 AM
mecdac's Avatar
Wink
Case in point:
Stewart
Facemop
Floor mopped with face.
OUCH
Curt hitch - report from towing section HoustonDave 1973 - 1979 F-100 & Larger F-Series Trucks 17 02-09-2017 10:39 AM
Any Large Span Locking Hitch Pins? Tractionless Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion 7 10-20-2016 09:03 AM
New Member to the forum sirkingdra New Member Introductions 0 03-15-2016 04:08 AM
Need help with hitch for my Flareside nikmish 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 10 06-03-2014 08:30 PM
Has anyone seen a rubber 2.5" hitch plug? Karl4Cat 1999 to 2016 Super Duty 5 08-22-2010 08:18 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
