ok whos a supercharger injection 351m/400 whipple expert ? - Ford Truck Enthusiasts Forums
Old 07-19-2014, 06:19 AM
Wodahs Wodahs is offline
Wodahs is starting off with a positive reputation.
my plan is to build up a 400 with a pair of cj v4 oc heads with aprox 76cc , an aprox 32cc forged anodised piston set with a ecu set up sequential spark and injection intake toped by a whipple with a valley mounted intercooler sunk down in the valley with a modified manifold (that I will build out of a twin carb cleveland one)
my estimate with them internals will put it at approx. 8 to 1 cr and with the 203 whipple at 12 psi it will end up in the area of an aprox high 13's 1 compression ratio
with hopefully an aod (or e4od) matched up behind it and ending with a 9" ratio of 3.25 to 1 in heavy ltd street car
so ok whos a supercharger injection 351m/400 whipple expert , what you kink and what am I missing or should be thinking about if any thing
also have a crower cam for this build and can post details and can discuss my ideas on the injection induction set up I have planned even the can sensor pick up and crank pick up I have planned
Old 07-20-2014, 12:35 AM
Blurry94's Avatar
Blurry94 Blurry94 is offline
Blurry94 has a very good reputation on FTE.Blurry94 has a very good reputation on FTE.Blurry94 has a very good reputation on FTE.Blurry94 has a very good reputation on FTE.
For something like this, I would steer away from the AOD unless it is built.
Are you looking at aftermarket EFI, and how do you plan on fueling your combo?
Old 07-22-2014, 05:05 AM
not sure if aftermarket or not as I have a new late model ford ecu efi system and if it can be moded to suit then may use
plan on fueling the combo ??? not sure the question there
and as for the aod yep id have one built and for high hp
picking up a 400 and will rebuild Wodahs 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 20 07-26-2014 09:59 PM
Supercharged 5.4 Superduty '99 5.4L DUTY 1999 to 2016 Super Duty 7 03-06-2014 10:02 AM
Whipple Supercharger for 5.4L Super Duty Furian 1999 to 2016 Super Duty 103 09-25-2012 04:59 PM
will the Lightning supercharger Bolt up to my DOHC 5.4 Robsride Modular V8 (4.6L, 5.4L) 10 06-28-2010 07:57 AM
Whipple Supercharger Ragger 2004 - 2008 F150 5 08-19-2009 04:49 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
