Fuel filter seperater - Ford Truck Enthusiasts Forums
Australia Chapter Join Chapter , Leader: ChunderDownUnder
Old 07-19-2014, 02:59 AM
Matseffie Matseffie is offline
Matseffie is starting off with a positive reputation.
Hi all ,, does any 1 no wer I can get a replacement part for the above mentioned ? There's a pipe that screws on to the top of this to the right side as you are looking from the front .my thread has been stretched and is leaking wer the pipe tightens on ?? (Not sure how to post a pic )
Old 07-19-2014, 03:14 AM
Old 07-19-2014, 07:51 AM
Patchy 73's Avatar
Patchy 73 Patchy 73 is offline
Patchy 73 has a very good reputation on FTE.Patchy 73 has a very good reputation on FTE.Patchy 73 has a very good reputation on FTE.
I see you are in Sydney
I would try a wrecker at first
Try to steer away from a Ford Stealership
Cheers,
Patchy
Old 07-20-2014, 05:25 AM
SSSimon SSSimon is offline
SSSimon has a great reputation on FTE.SSSimon has a great reputation on FTE.SSSimon has a great reputation on FTE.SSSimon has a great reputation on FTE.
Hi Matt,
that is the fuel return on the top of your truck's fuel bowl. Generally what happens is that the Aussie Ultra Low Sulphur Diesel (ULSD) disovles the stock fuel seal.
That black muck coming out both side of the brass nut is the memory of your old fuel seal there.
This is how you fix it:
Welcome to guzzle's Powerstroke Fuel Bowl Rebuild Web Page
This is where you get the parts to replace all the seals (20 USD + postage):
A complete Fuel Bowl reseal kit for the Ford 7.3L diesel filter canister 1999-2003
The seal that you've shown disolved is the: 1 - 5/16" sleeve for the fuel return line.
Based on my experience, if one goes the rest will follow, buy the military spec offering and spend a day doing the fuel-bowl rebuild, & it will be the last time that you have to touch it.
Body Line Adjustment '75HB250 1973 - 1979 F-100 & Larger F-Series Trucks 13 07-20-2015 09:49 AM
exhaust question jswford Ranger & B-Series 0 09-24-2014 09:11 PM
'66 rear axle 59INA40 1961 - 1966 F-100 & Larger F-Series Trucks 6 10-20-2010 03:24 PM
flexplate weight? wozxxx86 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 4 12-10-2004 04:26 PM
Black smoke and loss of power Blueghost Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 9 08-13-2004 11:58 PM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
