Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Ranger & B-Series
Sign in using an external account
Register Forgot Password?
Ranger & B-Series All Ford Ranger and Mazda B-Series modelsSPONSORED BY:
Old 07-19-2014, 01:43 AM
johnathan-13bravo johnathan-13bravo is offline
johnathan-13bravo is starting off with a positive reputation.
2wd to 4wd...?
I have a base 1983 Ford ranger 2.0L L4 4speed transmission 2wd and I wanna convert it to a 4wd pickup. I want to use the same transmission and upgrade to a V6 engine. What would work better a 3.0 L or 2.8L engine? Were there or are there any transfer cases that go to the transmission? What axles should I look into for the pickup?
Old 07-19-2014, 12:30 PM
Conanski's Avatar
Conanski Conanski is offline
Conanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud of
Quote:
That's not gonna work, a 2wd trans cannot be converted to 4wd easily and the V6 motors have a different belhousing bolt pattern so it's a no go on both counts. What you need is a complete powertrain.. engine, trans, t-case, driveshafts, and axles so you may as well find a donor truck, and at that point it's probably easier and quicker to put your body on the donors frame if it's in bad shape, or just go buy a 4wd truck.
__________________
Paul (Conan) O'Brien
1990 5.0HO AOD XLT X-Cab F150 3.55LS, 1994 3.0L 5-sp x-cab Ranger 3.45, 2004 3.0L 5-sp X-cab Ranger Edge 4.10, 2004 2.5L 5-spd Subaru Legacy
1996 Kawasaki ZX11D, 2004 Honda 599, 2008 Kawasaki KLR650
Old 07-19-2014, 09:17 PM
Transfer the body to a different frame? Okay, now I have to find a donor vehicle. What frame should I use? What a swap to any pickup frame work? What frame did this truck use?
Old 07-19-2014, 09:31 PM
DomsF250's Avatar
DomsF250 DomsF250 is offline
DomsF250 is starting off with a positive reputation.
I tried this on a Mail Truck CJ5 jeep years ago. Spent way more then the jeep was worth. Like 7K for a $ 3500 jeep. Way better IMHO to sell it and buy a 4WD to start. Unless it has sentimental value, it will be a pain in the...well you get the idea.
Old 07-19-2014, 11:20 PM
ranger pat's Avatar
ranger pat ranger pat is offline
ranger pat is gaining momentum as a positive member of FTE.ranger pat is gaining momentum as a positive member of FTE.
Find a 4WD Ranger with the same wheelbase as the 2WD one you have.
__________________
Joe
Old 07-20-2014, 02:41 PM
<p>It does have sentimental value to me. So does it have to be a Ranger or can it be any other vehicle? Like something that would fit the ranger body? It seems difficult but I bet it could be done. So I know this much, you can't put a RANGER body onto a SUV frame 'without' modifications. Would a Nissan frame do? Mazda's are the same thing as Rangers. What other car company pickup frame would work with the Ranger body?
thank you everyone who replies back!
thank you from El Paso Texas </p>
Old 07-20-2014, 08:20 PM
Conanski's Avatar
Yes it has to be a Ranger if you want it to be street legal and be a project you stand some chance of completing.
__________________
Old 07-20-2014, 08:40 PM
UNTAMND's Avatar
UNTAMND UNTAMND is offline
UNTAMND has a great reputation on FTE.UNTAMND has a great reputation on FTE.UNTAMND has a great reputation on FTE.UNTAMND has a great reputation on FTE.
Find something like a 93 explorer, use the complete front end and it will literally bolt into that ranger. Then use the engine frame mounts and bolt the 4liter and trans into it. Then bolt the big drum rear axle into it also to match the front gears.
Wiring is pretty good. The explorer has an engine bay harness and fuse box that is easy to modify. Strip out the headlight crap from the harness and go from there.
__________________
JR Strout..aim UNTAMND..00psd4x4ccsbLariet37sTwinTurbo
http://www.youtube.com/profile?user=untamnd#g/u
90 F150 xlt lariat supercab 4x4 long bed 5.8 auto red interior (stock for now) 61000miles
67 Mustang GTA Fastback 390 UNTAMND.com
Old 07-26-2014, 10:24 AM
piotrsko's Avatar
piotrsko piotrsko is offline
piotrsko is starting off with a positive reputation.
^^ UHH, NO. front end suspension mounts for 4 wd are different than 2wd, they are bigger. they are also riveted into the frame.. Trans mount has to be relocated forward, but transfer case from the same trans bolts where the shaft extension bolts. External slave on trans, IMHO is a better deal. Cologne series engine, don't remember off hand what else fits. 1.6, 2.0,2.3, 2.8, 2.9, 4.something?
front end only swap doesn't matter on wheel base.
Bronco 2's, mazda B series pick-ups fit. so do exploders if the axles look the same
BTDT,YMMV
__________________
2000 PSD CC LOOOOOng bed 6spd for the next 20 years (or more) AKA Oklahoma stretch limo
83/84/85/86/87/88 Ranger XLT 11" KOSTOV/chevy Volt li-ion <sold out here> (electric conversion) I love it when they ask me what year or engine
2 lines all 2pt.
Similar Threads
2wd 4wd FE part differences PHXCobra 1973 - 1979 F-100 & Larger F-Series Trucks 6 01-21-2014 11:15 AM
F250 -1991 2wd using a 4wd transmission, 4wd conversion maybe in future sverker 1987 - 1996 F150 & Larger F-Series Trucks 6 11-12-2011 07:03 AM
Automatic transmission swap question OldIronNut Ranger & B-Series 3 08-20-2008 12:00 PM
Tranny in truck straightsixer Clutch, Transmission, Differential, Axle & Transfer Case 1 10-23-2007 02:24 PM
93 F150 2WD to 4WD conversion hav0k Clutch, Transmission, Differential, Axle & Transfer Case 3 01-18-2004 10:55 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Participate In The Forums
Create new posts and participate in discussions. It's free!
Sign Up »
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Jobs
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
