O6 f250 horn not working
The horn is not working I changed the fuse for the horn and still don't work. The cruise control still works and the air bag light is not on. I can here the relay making a clicking noise when you push the horn just no sound. Does it sound like the horn is gone bad or could it be the relay? Thanks
Run a wire directly from the battery to the horn itself, touching the input tab---if it works you have an electrical path issue. If it doesn't then its the horn itself.
If its a path problem I'd suspect the relay contacts. Since it would be supposedly operating the lack of current to the horn suggests the contacts inside the relay housing.
cjcathey2002
12-10-2003 07:44 PM
