1996 F350 7.3l no start
Old 07-18-2014, 09:31 PM
SeanDrakejeeps's Avatar
SeanDrakejeeps
SeanDrakejeeps is offline
Angry 1996 F350 7.3l no start
ok guys I have a 1996 F350 that cranks but no start no fuel smoke
this is a list of things I have done I have checked all fuses and they are all good the oil level is right on the money and the tach is moving will cranking I checked the hpop with a gage in line hooked to the head I have 3600 psi of oil wile cranking I checked the fuel pressure and it is 45psi I pulled the return fuel line off the head and cranked it over the fuel flowed out of the head it will fire off of starting fluid but will not stay running I hooked up a snap on scanner to it.wile cranking I have 154 rpm my ICP is 3640 the ipr is 55% my fuel PW goes up to 4.04 and then drops back to 1.? IT has passed the buz test 6 times in a row there is no codes at all. any ides
Old 07-19-2014, 01:11 AM
Spktyr's Avatar
Spktyr
Spktyr is offline
Does the tach move while you're cranking? Did you check all the fuses in the main underhood box?
Old 07-19-2014, 08:35 AM
F350 1990's Avatar
F350 1990
F350 1990 is offline
this is a list of things I have done I have checked all fuses and they are all good the oil level is right on the money and the tack works I checked the hpop with a gage in line hooked to the head I have 3600 psi of oil wile cranking I checked the fuel pressure and it is 45psi I pulled the return fuel line off the head and cranked it over the fuel flowed out of the head it will fire off of starting fluid but will not stay running I hooked up a snap on scanner to it.wile cranking I have 154 rpm my ICP is 3640 the ipr is 55% my fuel PW goes up to 4.04 and then drops back to 1.? IT has passed the buz test 6 times in a row there is no codes at all. any ides
First check for presence of RPM signal (per suggestion above). Also, did you hear the glow plug relay click (or run a separate glow plug check ?)..
Then, If that Fuel PW is dropping (e.g. at/near 1ms or lower --.6ms) this is a "no fueling pulse" meaning a sync pulse has not been transmitted to the computer from the CMP or it is inconsistent
Was that buzz fairly consistent or "equal" across the injectors?
Early indications: PCM, CID, or IDM could be faulty
Also, I would not use ether either.........very bad
Old 07-20-2014, 04:28 PM
SeanDrakejeeps
yes as stated above all fusses are good and the tach is moving wile cranking yes the glow plugs work and yes all in the injectors were equal across the board .
the fuel PW ramped up to 4.04 and then dropped to 1.somthing (I don't remember and I didn't right it down ) what is the cid
Old 07-20-2014, 07:46 PM
F350 1990's Avatar
F350 1990
CID is cylinder identification............input used by the IDM to provide current to the correct injector
Old 07-21-2014, 06:21 PM
SeanDrakejeeps
ok how do i test this and where is it loacated
Old 07-21-2014, 06:43 PM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
If the glow plug relay is disconnected and a shot of either is given. It will hurt NOTHING.
Also, you should be seeing a hell of a lot more RPM than 154. No less than 500. Which tells me CPS
Old 07-21-2014, 08:34 PM
1993_f350_2013's Avatar
1993_f350_2013
1993_f350_2013 is offline
If it's not the CPS than it might be the high pressure fuel regulator. It's on the driver side of the hpop. We've had to replace the orings on them in two if our 1996 7.3's. I'm pretty sure you have to buy the whole thing and not just the orings
Old 07-22-2014, 08:48 AM
SeanDrakejeeps
I would think if it was the o rings I would have low oil psi not 3,640 psi of oil pressure an I wrong on this thought. and yes I did disconnect the glow plugs when I shot it with either It close to 100 deg f here right now so I know I can rule out the glow plugs being the problem
Old 07-22-2014, 08:49 AM
SeanDrakejeeps
for some reason the fuel is just not getting into the combustion chamber there is no smoke at all
Old 07-22-2014, 09:40 AM
danr1's Avatar
danr1
danr1 is offline
A question wasn't directly addressed worth repeating,
Old 07-22-2014, 07:16 PM
SeanDrakejeeps
ok again YES YES YES the tach is moving wile it is cranking Sorry I guess i did not make that clear
Old 07-22-2014, 07:21 PM
SeanDrakejeeps
one other thing i might add that i did not earlyer is the cps is new it was the frist thing i checked. but if the cps is bad how would the scanner see anr rpm at all
Old 07-23-2014, 04:57 AM
Diesel_Brad
That it is reading the WRONG RPM. You should have at least 500rpm turning it over with the starter, NOT the 100 or so you are seeing. And you are truly only getting 100 RPM with the starter, it is NOT spinning fast enough to start
Old 07-23-2014, 06:18 PM
SeanDrakejeeps
OK thanks brad I will check that out and make sure the cps is seated in the hole compleatly It is spinning over just as fast as it always has so i will look in to this
Quick Reply: 1996 F350 7.3l no start
