1996 F350 7.3l no start - Ford Truck Enthusiasts Forums
Old 07-18-2014, 10:31 PM
SeanDrakejeeps SeanDrakejeeps is offline
SeanDrakejeeps is starting off with a positive reputation.
Angry 1996 F350 7.3l no start
ok guys I have a 1996 F350 that cranks but no start no fuel smoke
this is a list of things I have done I have checked all fuses and they are all good the oil level is right on the money and the tach is moving will cranking I checked the hpop with a gage in line hooked to the head I have 3600 psi of oil wile cranking I checked the fuel pressure and it is 45psi I pulled the return fuel line off the head and cranked it over the fuel flowed out of the head it will fire off of starting fluid but will not stay running I hooked up a snap on scanner to it.wile cranking I have 154 rpm my ICP is 3640 the ipr is 55% my fuel PW goes up to 4.04 and then drops back to 1.? IT has passed the buz test 6 times in a row there is no codes at all. any ides
Old 07-19-2014, 02:11 AM
Spktyr Spktyr is offline
Spktyr is gaining momentum as a positive member of FTE.Spktyr is gaining momentum as a positive member of FTE.
Does the tach move while you're cranking? Did you check all the fuses in the main underhood box?
Old 07-19-2014, 09:35 AM
F350 1990's Avatar
F350 1990 F350 1990 is offline
F350 1990 is starting off with a positive reputation.
Quote:
this is a list of things I have done I have checked all fuses and they are all good the oil level is right on the money and the tack works I checked the hpop with a gage in line hooked to the head I have 3600 psi of oil wile cranking I checked the fuel pressure and it is 45psi I pulled the return fuel line off the head and cranked it over the fuel flowed out of the head it will fire off of starting fluid but will not stay running I hooked up a snap on scanner to it.wile cranking I have 154 rpm my ICP is 3640 the ipr is 55% my fuel PW goes up to 4.04 and then drops back to 1.? IT has passed the buz test 6 times in a row there is no codes at all. any ides
First check for presence of RPM signal (per suggestion above). Also, did you hear the glow plug relay click (or run a separate glow plug check ?)..
Then, If that Fuel PW is dropping (e.g. at/near 1ms or lower --.6ms) this is a "no fueling pulse" meaning a sync pulse has not been transmitted to the computer from the CMP or it is inconsistent
Was that buzz fairly consistent or "equal" across the injectors?
Early indications: PCM, CID, or IDM could be faulty
Also, I would not use ether either.........very bad
Old 07-20-2014, 05:28 PM
yes as stated above all fusses are good and the tach is moving wile cranking yes the glow plugs work and yes all in the injectors were equal across the board .
the fuel PW ramped up to 4.04 and then dropped to 1.somthing (I don't remember and I didn't right it down ) what is the cid
Old 07-20-2014, 08:46 PM
F350 1990's Avatar
CID is cylinder identification............input used by the IDM to provide current to the correct injector
Old 07-21-2014, 07:21 PM
ok how do i test this and where is it loacated
Old 07-21-2014, 07:43 PM
Diesel_Brad's Avatar
Diesel_Brad Diesel_Brad is offline
Diesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud of
If the glow plug relay is disconnected and a shot of either is given. It will hurt NOTHING.
Also, you should be seeing a hell of a lot more RPM than 154. No less than 500. Which tells me CPS
Old 07-21-2014, 09:34 PM
1993_f350_2013's Avatar
1993_f350_2013 1993_f350_2013 is offline
1993_f350_2013 is gaining momentum as a positive member of FTE.1993_f350_2013 is gaining momentum as a positive member of FTE.
If it's not the CPS than it might be the high pressure fuel regulator. It's on the driver side of the hpop. We've had to replace the orings on them in two if our 1996 7.3's. I'm pretty sure you have to buy the whole thing and not just the orings
Old 07-22-2014, 09:48 AM
I would think if it was the o rings I would have low oil psi not 3,640 psi of oil pressure an I wrong on this thought. and yes I did disconnect the glow plugs when I shot it with either It close to 100 deg f here right now so I know I can rule out the glow plugs being the problem
Old 07-22-2014, 09:49 AM
for some reason the fuel is just not getting into the combustion chamber there is no smoke at all
Old 07-22-2014, 10:40 AM
danr1 danr1 is offline
danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.
A question wasn't directly addressed worth repeating,
Quote:
Old 07-22-2014, 08:16 PM
ok again YES YES YES the tach is moving wile it is cranking Sorry I guess i did not make that clear
Old 07-22-2014, 08:21 PM
one other thing i might add that i did not earlyer is the cps is new it was the frist thing i checked. but if the cps is bad how would the scanner see anr rpm at all
Old 07-23-2014, 05:57 AM
That it is reading the WRONG RPM. You should have at least 500rpm turning it over with the starter, NOT the 100 or so you are seeing. And you are truly only getting 100 RPM with the starter, it is NOT spinning fast enough to start
Old 07-23-2014, 07:18 PM
OK thanks brad I will check that out and make sure the cps is seated in the hole compleatly It is spinning over just as fast as it always has so i will look in to this
96' 4.9L F-150 Idle hickup... Grim_F150Mike 1987 - 1996 F150 & Larger F-Series Trucks 10 09-04-2014 10:13 AM
6.0L No Start Mystery dpassarella 6.0L Power Stroke Diesel 17 03-30-2014 08:55 PM
99-7.3 No Start after Inj-o-ring build GlennSwett 1999 - 2003 7.3L Power Stroke Diesel 144 03-13-2014 12:08 PM
Only starts with brake cleaner. brandonnichols 1987 - 1996 F150 & Larger F-Series Trucks 12 03-06-2014 02:18 PM
Early 99' 7.3L start problem.............HELP!!!!!!!!! mudboy87 1999 - 2003 7.3L Power Stroke Diesel 20 07-02-2013 10:12 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
