88 f150 single cab rear speakers - Ford Truck Enthusiasts Forums
Old 07-18-2014, 06:44 PM
Rusty72782 Rusty72782 is offline
Rusty72782 is starting off with a positive reputation.
Just had a quick question to see if anyone had any info on installing rear speakers on an 88 f150 single cab. There is not any stock rear speakers and was wondering if anyone has any ideas. I am tall so speaker boxes for 69's won't work. Thank you!
Old 07-19-2014, 12:15 PM
Redneckfordf2502002's Avatar
Redneckfordf2502002 Redneckfordf2502002 is offline
Redneckfordf2502002 has a superb reputationRedneckfordf2502002 has a superb reputationRedneckfordf2502002 has a superb reputationRedneckfordf2502002 has a superb reputationRedneckfordf2502002 has a superb reputationRedneckfordf2502002 has a superb reputationRedneckfordf2502002 has a superb reputationRedneckfordf2502002 has a superb reputationRedneckfordf2502002 has a superb reputationRedneckfordf2502002 has a superb reputationRedneckfordf2502002 has a superb reputation
We use to have a 86 F150 single cab that the POs put speaker boxes in and put it behind the seat. The only thing I hated about that was they got in the way when putting stuff behind the seat.
On my 88 F150 single cab I am going to go a slightly different route. I have two rear speakers out of a 92 extended cab ranger with the brackets that I am going to put on the seat but out of the way some so that things don't hit them.
The same style speakers my dad will be installing in his 89 F250 single cab. His came from the rears of a 94 Bronco. His also are going to be easier because of the custom installed bucket seats that I installed.
Trav
Old 07-19-2014, 12:25 PM
Diesel_Brad's Avatar
Diesel_Brad Diesel_Brad is offline
Diesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud of
Get some 92-97 reg cab B pillar covers covers and while you are there look and see how the factory mounted the 6x9s
Old 07-19-2014, 03:53 PM
Eddiec1564 Eddiec1564 is offline
Eddiec1564 has a very good reputation on FTE.Eddiec1564 has a very good reputation on FTE.Eddiec1564 has a very good reputation on FTE.Eddiec1564 has a very good reputation on FTE.
On the 92 to 96 reg cab B pillar covers, the speakers directly mount to them and requires the older cabs to have some metal trimmed to clear the speakers. The Also the seat belt loop bolt hole in the 92's and up B pillar covers will need to be "adjusted" for the older cabs too.
I think(kinda forgot) the speaker size are 5x7 not 6x9 for a direct fit of the 92 and up B pillar covers
Now to put a sub box behind the seat or go with a 8" tube subwoofer. Anybody have some box sizes?
Adding Rear Speakers w/ Base A/M-F/M Radio- 2005 F-350 Supercrew 05f350supercrew Audio & Video Systems, Navigation, Satellite Radio & Mobile Electronics 0 04-16-2016 10:21 PM
F-250 Std Cab - Should I put my new speakers in front or back? Syncrowave 1999 to 2016 Super Duty 7 03-02-2016 04:16 PM
ext cab and rear speakers mario9272 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 3 11-05-2014 09:59 PM
quick door speaker connection question! 6ohman2004 1973 - 1979 F-100 & Larger F-Series Trucks 15 02-06-2014 01:37 PM
'96 F150 Ext. - Left Rear Speaker Install RBrasher 1987 - 1996 F150 & Larger F-Series Trucks 5 08-11-2012 09:51 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
