Wireless Throttle 'Corrector' Gadget - Ford Truck Enthusiasts Forums
Old 07-18-2014, 03:52 PM
1saxman's Avatar
1saxman 1saxman is offline
1saxman is gaining momentum as a positive member of FTE.1saxman is gaining momentum as a positive member of FTE.
I'm starting to see these gadgets that you plug into the wireless throttle connector that cancels/modifies the delay programming that opens the throttle plate in the throttle body for better response. Maybe this is not so much of a problem with an auto trans, but for those very few of us with a V6 and stick shift, it is very aggravating - hard to make a smooth take-off, and you just don't get that instant throttle response you need in shifting gears. I know part of it could be the MAF needs cleaning and I'm going to do that first and see how it goes. Just wondering if anyone has tried one of these gadgets.
Old 07-18-2014, 05:05 PM
danorules's Avatar
danorules danorules is offline
danorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputation
I bought an edge programmer and it improved throttle response quite a bit. It also helped other aspects ie: shifting, torque,and power. Not sure how much the gadget you are talking about costs, but if it's close I would get the edge.
Need some dash help siesta 1968-2013 Full Size Vans 17 01-17-2017 06:38 PM
Both Heated seats stopped on 2003 expedition at same time 2003EB Electrical Systems/Wiring 38 08-01-2016 06:56 AM
96 F150 4.9 has spark, fuel and will crank but no start. InfantryCPT 1987 - 1996 F150 & Larger F-Series Trucks 27 11-12-2015 05:36 PM
Easier way to fill rear end? bigcountry1009 1999 to 2016 Super Duty 21 10-27-2014 11:46 PM
bitsy bitsy Ranger & B-Series 4 08-30-2014 12:09 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
