OD light flashes and CEL comes on sometimes :(
Pulled the codes and erased them a few days ago for the first time and now it's about a once a day thing. I can drive for 2-3 stops and then I come out of a place, get in the truck, and when I start it up I have the light and the OD flashing. This is what the commander says:
Please don't tell me it's a COP
On the rear of the transmission, up top you'll find something that looks like a little like this. Check the connection, and also pull it and see if the end of the sensor is cracked, sometimes they crack and let fluid in. I believe the actual sensor pictured is the TSS, but they are similar in design and function.
Yes. I think you need to determine if the sensor is bad, or if you have a bad connection or a damaged wire to the OSS.
I didn't see anything in the video that looks bad. The yoke is NOT falling out of the transmission. It moves in and out as the rear axle moves up and down. That's normal.
Time stamped 6:25 PM last night......He hasn't posted anything since....
Mark do we need to send out a search and rescue crew for him?
BTW what is the testing procedure for that sensor on the transmission?
