Truck keeps dying - Ford Truck Enthusiasts Forums
Truck keeps dying
Old 07-18-2014, 03:07 PM
Solidaxlef250 Solidaxlef250 is offline
Solidaxlef250 is starting off with a positive reputation.
Truck keeps dying
I have a 1993 F250 four-wheel drive with a 351 Windsor and a 5 speed manual. Lately I have been having problems with it running. It will start but it will rev high and then sound like it's gonna die and will either die or rev high again and continue doing that till it dies. Sometimes when I start it, it will start up fine and run fine for a little bit but then when eventually start reving really high and then die. And then sometimes I'll be driving it and it will randomly just die. I have no idea what's going on with it. If somebody could help that I would greatly appreciate it.
Old 07-18-2014, 09:29 PM
Inline6xl Inline6xl is offline
Inline6xl is starting off with a positive reputation.
I would check the vacuum lines. Mine did the same thing then would idle low and stall when I wasn't even in gear. The vacuum line going to the idle air controller was creased and eventually split. Changed it and I was good to go
Old 07-18-2014, 11:41 PM
rla2005's Avatar
rla2005 rla2005 is online now
rla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud of
Quote:
The IAC on this vintage truck is electronic controlled by the computer, there is no vacuum connection to it.
88 f250 randomly dying/not starting bk1200r 1987 - 1996 F150 & Larger F-Series Trucks 1 08-17-2016 10:31 PM
6.0 f250 Cold Starts fine -- Stalls immediately after, no throttle low RPM, has to stay at 2.5k+ Deiboe 6.0L Power Stroke Diesel 8 02-17-2016 04:12 PM
88 f250 w/ 460 running issues. Dscortdady Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 0 05-30-2015 11:27 AM
Starts an then dies when cold. 4drf350 1994.5 - 1997 7.3L Power Stroke Diesel 3 04-01-2015 01:32 PM
HELP!!!PROBLEMS!!!2002 Ford explorer sport trac 4x4 Dixie Mills 3.8 & 4.2L V6 0 08-20-2014 08:23 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
