Bad Ground / Lightning Damage - Ford Truck Enthusiasts Forums
Old 07-18-2014, 01:37 PM
TallEddie1981 TallEddie1981 is offline
TallEddie1981 is starting off with a positive reputation.
I don't have a problem anymore, just looking to see what people think of the situation I just had with my truck.
This past week I was at a campground, and there was a really bad thunderstorm. I swear there was a direct lightning hit somewhere on the campground. The sound was almost unbelievable. A lot of electronics and electrical stuff was damaged at the campground office.
Anyway, the next morning I went to start my truck. When I turned the key, nothing happened. The lights/radio,instrument cluster all lit up, but no crank. Plugged in my scan tool and it wouldn't read the computer, said turn key to on or start position. So the PCM wasn't powering up. Luckily a local Ford dealer was able to solve the problem, a broken ground for the PCM.
Here is my question, is it possible that the lightning strike did this. I've read a lot of conflicting information online about lightning strikes and cars. I would think that if lightning did strike a car, the energy would go into the grounding system. This is really just a curiosity for me, the truck is fixed. It just seems like a really big coincidence to have a huge lighting strike and then have an electrical problem with my truck. Especially with a ground, which is what I assume would take the strike.
So what is your opinion on this.
Thanks.
Old 07-18-2014, 02:06 PM
David7.3's Avatar
David7.3 David7.3 is offline
Where is the beer?
David7.3 is a splendid one to beholdDavid7.3 is a splendid one to beholdDavid7.3 is a splendid one to beholdDavid7.3 is a splendid one to beholdDavid7.3 is a splendid one to beholdDavid7.3 is a splendid one to beholdDavid7.3 is a splendid one to behold
I can't see it, just one ground and no damage to any electronic parts? could it just have been time for that ground to fall off or corrode off. I had a direct hit in my truck waiting for a storm to pass, yes its loud. After changing my underwear, started the truck right up and drove home, still going today. this was about 2 years ago. but you never know, i'm sure we all have seen weird things.
Old 07-18-2014, 03:44 PM
1saxman's Avatar
1saxman 1saxman is offline
1saxman is gaining momentum as a positive member of FTE.1saxman is gaining momentum as a positive member of FTE.
Like David said, a vehicle is a good place to be in an electrical storm because the tires insulate it from the ground. I agree the problem appears to be co-incidental. Its not a bad idea to go over the truck every year or so, find all the grounds you can and treat each one with a little 'Corrosion-X'.
Fix Door Closure Problem Treacy 1987 - 1996 F150 & Larger F-Series Trucks 0 07-06-2016 05:47 PM
Outfitting for trip to Alaska. 2005 Ex Limited 6.0L Power Stroke Diesel 28 05-06-2016 09:18 AM
The magic of 37 mph jackstraw 1999 - 2003 7.3L Power Stroke Diesel 3 11-07-2014 11:05 AM
Damage From Lightning Strike Hostel17 6.7L Power Stroke Diesel 15 08-24-2014 05:10 AM
I think my GPM just exploded jackstraw 1999 - 2003 7.3L Power Stroke Diesel 28 07-18-2014 08:07 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
