1988 F350 intermittent ignition trouble - Ford Truck Enthusiasts Forums
Old 07-18-2014, 10:51 AM
Brandon Humphries Brandon Humphries is offline
Brandon Humphries is starting off with a positive reputation.
Im working on a 88 F350. The truck starts fine cold. After it starts up the first time and is driven, it won't start back up until it cools off or sits about 30 minutes. It has 40psi of fuel pressure and all the ignition components have been replaced including a new distributor. Have any ideas??
Old 07-18-2014, 11:11 AM
rla2005's Avatar
rla2005 rla2005 is offline
rla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud of
When it stops running have you determined if the fuel pressure drops out or is it losing spark?
Was the "new" distributor really new or rebuilt?
Old 07-18-2014, 11:26 AM
The fuel pressure is good. Its loosing spark intermittently
Old 07-18-2014, 11:27 AM
Its a reman distributor but it did the same thing before it was replaced
Old 07-18-2014, 11:56 AM
Phil Woolfson's Avatar
Phil Woolfson Phil Woolfson is offline
Phil Woolfson is starting off with a positive reputation.
I just had a similar problem and finally traced it (I hope) to the fact that the ignition switch was too far back on the column. You can rule this in or out by seeing if the radio comes on in the rear (ACC) position. If it does, it's something else. If it doesn't, adjust the switch and see if it helps.
Old 07-18-2014, 02:11 PM
Quote:
I just replaced the switch. I'll try adjusting it again
Old 07-18-2014, 02:51 PM
subford's Avatar
subford subford is online now
subford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud of
Most reman distributors are bad and do that. If you can get a good one without replacing it four times you are doing good.
Or you can just replace the PIP sensor that is mounted on the stator inside the distributor.
What code are you getting in CM? PIP sensor?
Old 07-19-2014, 10:02 AM
No codes! It just loses spark and then after it sits for about 30 minutes and then it starts right back up. And it'll run all day as long as I don't shut it off
Old 07-19-2014, 10:09 AM
subford's Avatar
Next time it has no spark unplug the SPOUT and see if spark returns. If not then unplug the PCM Computer and then see if you have spark.
If still no spark and no codes in CM you either have a bad ICM or Ignition coil or no power to the Ignition coil.
Check for power at the Ignition coil with a test light and the key on or cranking. It should light at both wires going into the Ignition Coil (flashing on one if cranking).
If no power at the Ignition coil then look at the Ignition switch.
Old 07-19-2014, 10:11 AM
rla2005's Avatar
Quote:
Please define "No codes". If the KOEO tests pass then you get System Pass code 11. The same if there are no stored codes in CM. If you get no codes that could mean you have a bad computer (PCM) or a bad connection at the diagnostic port.
Old 07-19-2014, 11:14 AM
I've already done all that. I installed a new ignition switch too. It could be I need to adjust the ignition switch again.
Old 07-19-2014, 11:15 AM
System pass everytime
Old 07-19-2014, 11:20 AM
rla2005's Avatar
Thank you for the clarification. There is a huge difference between "no codes" and System Pass code 11. The troubleshooting path is completely different.
Old 07-19-2014, 11:29 AM
You're welcome
Old 07-20-2014, 10:00 AM
I still haven't found a solution!
ignition switch mattb77 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 10 10-21-2016 10:34 PM
Ignition Hot Wire montauk1 1999 to 2016 Super Duty 5 07-24-2016 02:20 AM
Hopefully a simple, cheap fix.. '80 F150 ignition VolvoMatt 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 11 07-04-2016 10:52 AM
1969 f-250 ignition problems tuckerbandit 1967 - 1972 F-100 & Larger F-Series Trucks 3 10-20-2014 12:31 PM
Ignition sticking squirrel64 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 17 12-09-2013 08:59 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
