1988 F350 intermittent ignition trouble - Page 2 - Ford Truck Enthusiasts Forums
Old 07-20-2014, 09:02 AM
subford's Avatar
subford subford is online now
subford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud of
Did you do what I said in post #9 above?
Old 08-01-2014, 12:35 PM
Brandon Humphries Brandon Humphries is offline
Brandon Humphries is starting off with a positive reputation.
I have tried everything that was posted. It still has an intermittent ignition problem. 2 distributors 4 Ecms and 2 tfi modules. Still has 40 psi of fuel pressure while cranking. It'll start and and run but when I shut it down, it will NOT start back for about 20 minutes. It has 0 spark when it won't start.
Old 08-01-2014, 04:03 PM
subford's Avatar
Did the spark return when you unplugged the SPOUT or Computer?
Have you replaced the Ignition coil?
Old 08-02-2014, 07:34 AM
The spark returned one time when I removed the spout connector. The coil, ignition switch, ecm, dist and coil have been replaced. I cant figure this one out
Old 08-02-2014, 07:50 AM
subford's Avatar
If the spark comes and goes when removing the SPOUT and putting it back in then that points to the Computer. If the spark does not return when you pull out the SPOUT shorting bar then unplug the computer and see if the spark does not return then. If so take computer back and get another one as they sold you a bad computer.
Old 08-02-2014, 07:55 AM
F350 1990's Avatar
F350 1990 F350 1990 is offline
F350 1990 is starting off with a positive reputation.
Quote:
I'd recheck timing (it may be advancing too far preventing start up) and check spout voltages on the spout leads (below 5V ref is a problem) to confirm it's increasing (up to approx 2/3rds 12V) with the spout connected .
I'd also run some primary and secondary ignition checks with a spark tester, clean up all the ground connections in these circuits for housekeeping.
Old 08-02-2014, 01:52 PM
I've installed 6 different computers in this truck. That's not the problem
Old 08-02-2014, 02:23 PM
subford's Avatar
Have you checked or changed the ECT & the ACT sensors?
Old 08-02-2014, 03:00 PM
GarageSupervisor's Avatar
GarageSupervisor GarageSupervisor is offline
GarageSupervisor is starting off with a positive reputation.
Brandon, You seem to be getting good advice about checking primary, secondary ignition, ECT, and ACT. I have seen faulty sensors provide out of range and/or erroneous values and still pass self check.
Computers, even your "old" EEC version, do age but the likelihood of failure is low in the overall power management scheme. The associated wiring, harnesses do, however, factor in prominently and thus require your evaluation.
ignition switch mattb77 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 10 10-21-2016 09:34 PM
Ignition Hot Wire montauk1 1999 to 2016 Super Duty 5 07-24-2016 01:20 AM
Hopefully a simple, cheap fix.. '80 F150 ignition VolvoMatt 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 11 07-04-2016 09:52 AM
1969 f-250 ignition problems tuckerbandit 1967 - 1972 F-100 & Larger F-Series Trucks 3 10-20-2014 11:31 AM
Ignition sticking squirrel64 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 17 12-09-2013 07:59 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
