What to look for in a 99 F250 SD
I'm going to look at a '99 F250 super duty tonight. Its a 5.4L extended cab auto., W 232K on it. Needs a couple things like a rear brake line and it has an exhaust leak behind the muffler (its an opportunity to put a nice free flowing exhaust on). Plus the owner told me it needs a new center support for the driveshaft. He said it makes a sqeaking noise. But said everything else works fine. My question is what should I know and look for on this truck?
on
Power door locks seem to go weak to inoperative, but there are many documented fixes here on FTE.
Power windows start really slowing down a lot and drawing a lot of current.
Not sure about the 5.4, but Spark Plugs can be a bugger to replace and some have been known to strip the threads out of the heads.
Exhaust manifold leaks at the heads are indicative of missing/broken studs which can be a real PITB to fix - sometimes requiring the heads to be removed.
If it is a 4x4, make sure that the front hubs lock and unlock alright and that the transfer case is not leaking and functional.
Find out the manufacture date on the door sticker to see if it is an early 99 or late 99. If I remember correctly, March of 99 is the dividing line. The front brake and hub assemblies are different (and more expensive) on the early 99's, BUT you can upgrade to the later components like I did. Track bar and brackets are different also, so if your plans include lifting/leveling, its good to know what you are dealing with.
If you go to change your spark plugs, follow instructions you can find on this site and TORQUE THEM PROPERLY TO SPEC. Plug blowouts on these motors are directly related to improper torque- you don't ratchet them down tight like you could on the old V8's.
250,000 miles on my early-99 2v and no plugs have been puked...
Good advice guys! I looked at it, Needs a tune-up, no codes are stored. But the battery was dead so no real telling there until it gets driven. The passenger side door doesn't latch. The latch is open but it doesn't snap shut to hold the door closed. I dont like that. Needs a whole exhaust and a real good cleaning. Its a total work truck with the rubber flooring. I'm going to want to get carpet since my family will ride in it. But the thought of hosing out the interior after they ride in it is entertaining. Its 2wd and I would like to swap it over to a 4wd. My question is do they have manual transfer cases for these? Or are they mostly the electronic crap? I've sourced a D60 locally with 3:73's for $575. It has all the steering arms attached so the swap over seems on the front end to be easy. But I know somewhere there will be a problem...LOL!
I made him a respectable offer and he wants to let three other guys take a look and make an offer. He said if mines the highest I get it. I hope none of them show up, lol. Anyhow, its good to get all this info and thanks again guys!
I hope you're getting a deal that reflects the work you'll have to do. Don't pay top-dollar price.
That said, in 99, you could get either an electronic transfer case or a manual one.
Also take note of WHICH 99 you have- there is an "early-99" and a "late-99" with March being the dividing line. If you have an early-99, do your conversion with late-99 parts! Trust me, it will save you money and anything aftermarket (like a lift) will be easier to find.
Well looks like a lot of it has been covered.
Find out where it has spent most of it's life.
If it lived in the rust belt then you need to look
deeper to see how much hidden rust pockets
it has. Also any missed/ignored maintenance.
Does the transmission's cherry juice look and smell
more like burnt coffee?
Sean
Sean
Either way you go, it's $179 to replace carpet, $195 to replace vinyl. Neither is really a huge expense, about a tank of diesel for a lot of people now. If you don't like what comes in the truck, switch it out. After 15 years it might need new vinyl anyways.
Superduty Extended Cab Front Vinyl Floor Cover Black
1999-2008 Ford Super Duty/F-250/F-350/Excursion Extended Cab
I think this used to be the prevailing wisdom because every Super Duty ever made was still a fairly new vehicle, most under 10 years old and ALL under 15 years old. So a 4x4 conversion was actually destroying residual value, especially in the oldest models with 7.3s that people covet for the motor, and there were plentiful 4x4 options for similar cost in the same generation of truck. Now that the original trucks are starting to hit bottom value regardless of powertrain, options, etc, and they aren't really distinguishable from the OBS trucks, and a 4x4 swap is just parts cost, nothing else. If you get a solid '99 that's set up how you want it, and donor 4x4 might be cheaper than buying a truck with a 4x4 powertrain and a donor truck for trim parts, or upgrading the trim separately. When you're talking 08+, maybe even 05+, the conversion probably doesn't make sense, but for the older SDs, cost wise it's starting to become more of a viable option.
